> odd/annoying noise
post May 24, 2007 - 8:45 PM
cg97
Joined Nov 30, '05
From British Columbia, Canada
my car is making a wierd noise. when i first turn it on in the morn, idles around 1800 for a few min, then when i drive, if its over 3500ish rpm, my car makes a high pitched whine/squeel. me and my mechanic friend looked at it but we couldnt figure out what it was without taking anything apart. anybody have any idea? oh and it appears that it has to be in gear for the whine/squeel to happen. if its in neutral or if the clutch is it, it doesnt make the noise. thanks
post May 25, 2007 - 6:09 AM
bindertch
Joined Aug 18, '04
From Silverdale, WA
What gear or gears? If it is in all gears no matter what speed then your input bearing on your trans is out.
post May 25, 2007 - 11:55 AM
cg97
Joined Nov 30, '05
QUOTE(bindertch @ May 25, 2007 - 6:09 AM) [snapback]561427[/snapback]
all gears but have to be over 3500ish rpm
post Jul 17, 2007 - 10:28 PM
cg97
Joined Nov 30, '05
so bit of an update, it still does it around 3500 rpm and more, a mechanic told me it was a vacuum unit? anybody have any ideas?
Lo-Fi Version Time is now: April 21st, 2025 - 1:23 PM
