> Help with halfshaft, Cant remove drives side halfshaft
post May 25, 2007 - 2:55 PM
bcelica555
Joined Mar 24, '06
From East Berlin PA
I was trying to replace my drives said halfshaft and I cant get it to pull out...Is this anything in specific that would help me to get it out...Any information would help??
nvm got it out sorry for the stupid post
post May 25, 2007 - 3:51 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Get a long handled pry bar (like 24 inches or so), place the the wedge in front of the axle cup (between the transmission and cup), gently pry out the axle with the bar using your hand, while pulling on the cup with your other hand. It should pop out, just give it a gentle try.
There is a snap ring that holds the axle in place. Thats what makes it so hard to pull out.
I will return one day.
post May 26, 2007 - 4:54 PM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
Don't pull on the axle shaft, it will pull the CV joint apart. A special tool is made for using with .a slide hammer, but the prybar will work. Here's apic.
http://www.brandsplace.com/0246-otc7507.html
Lo-Fi Version Time is now: November 24th, 2024 - 1:24 AM
