im stupid but i ran into problem help!!!, car wont start |
May 25, 2007 - 9:39 PM |
Enthusiast Joined Apr 4, '05 From ST PAUL, MN Currently Offline Reputation: 3 (100%) |
well kk here is the problem..today i decided to start my car..when i did finally tried to start the beast..she wouldnt start just clicked clicked..only some of the assasor lights came on..i then decided to shut her off..messed around with my harness..then try and attemped to start her again this time all the lights came on inside the everything worked on the inside....but it still just clicked...i checked the grounds..one of them was loose i tighten that one put the battery back this time when the negative just sparked the tranny ground sparked with it..BAME that was when everything didnt work anymore..none of the lights inside worked... the car was dead...so that was my story and so if anyone have a clue please help me...figure this out?? thanks
May 25, 2007 - 10:36 PM |
Enthusiast Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
Start by checking your fuses.
And don't forget to test the battery. -------------------- _Gary
May 25, 2007 - 10:39 PM |
any clue why my starter isnt working or the engine wont crank over??
Enthusiast Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
QUOTE(RUNNIN-LOW @ May 25, 2007 - 9:39 PM) [snapback]561662[/snapback] well kk here is the problem..today i decided to start my car..when i did finally tried to start the beast..she wouldnt start just clicked clicked..only some of the assasor lights came on..i then decided to shut her off..messed around with my harness..then try and attemped to start her again this time all the lights came on inside the everything worked on the inside....but it still just clicked...i checked the grounds..one of them was loose i tighten that one put the battery back this time when the negative just sparked the tranny ground sparked with it..BAME that was when everything didnt work anymore..none of the lights inside worked... the car was dead...so that was my story and so if anyone have a clue please help me...figure this out?? thanks sounds like the battery is dead |
Jun 1, 2007 - 10:54 AM |
Enthusiast Joined Dec 14, '06 From MN, USA Currently Offline Reputation: 2 (100%) |
Check battery, grounds and fuses... and after check again.
Jun 1, 2007 - 11:42 AM |
Enthusiast Joined May 14, '07 From Long Island Currently Offline Reputation: 0 (0%) |
maybe starter if fuses&battery are good
-------------------- 94 Celica ST - CAI, CarPuter, many interior mods!
Jun 1, 2007 - 1:04 PM |
QUOTE(RUNNIN-LOW @ May 25, 2007 - 11:39 PM) [snapback]561679[/snapback] any clue why my starter isnt working or the engine wont crank over?? your battery has just enough juice to power the lights on the dash, but not enough amps to crank the starter. time to buy a new battery. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 1, 2007 - 9:12 PM |
Enthusiast Joined Dec 16, '06 From Maryland Currently Offline Reputation: 0 (0%) |
charge up or get a new battary first.
was the car sitting awhile or did you wash the bay out or something? |
Lo-Fi Version | Time is now: January 12th, 2025 - 1:45 PM |
