> front door/speaker question, How to???
post May 30, 2007 - 4:31 PM
Valo666
Joined May 15, '05
From Toronto
Im gonna be installing my new speakers in my doors on friday and im just trying to figure out how to get em off and if the adaptors i got with my speakers will fit.
this is the adaptor i got with the speakers, they are 6.5" JBLs
would that work with the front speakers?? I remember there was somethin strange about the size of the front speakers and most ppl had to order thouse adaptor plates off the net.
Any ways, back to the door pannel question, im guessin there is thouse 2 or 3 clips at the front, taking off the door handel cup, and then im lost there. Is it just clips???
Any help would be great. Thanks
Bryan
post May 30, 2007 - 4:47 PM
manphibian
Joined Oct 13, '06
From UK
Ok,
First, as you said take out the screw in the handle cup and remove that.
Then take out the large gold screw inside there holding the panel in place.
Then, there are two screws under the two round pop off cover caps near the front of the panel.
One screw in the hole in the armrest
4 screws along the bottom edge
3 small round clips on the outside edge
then lift up and remove
EDIT: Before removing, prise up the elec window switch panel from the back edge, and the red light, and disconnect them.
This post has been edited by manphibian: May 30, 2007 - 4:51 PM
post May 30, 2007 - 4:55 PM
bman
Joined May 14, '07
From Long Island
those "look" like they will be fine - and the door directions from manphilibian could not be better!
94 Celica ST - CAI, CarPuter, many interior mods!
post May 30, 2007 - 5:03 PM
Valo666
Joined May 15, '05
From Toronto
thanks luke..now just for the speaker question. Would thouse work???
post May 30, 2007 - 5:20 PM
manphibian
Joined Oct 13, '06
From UK
QUOTE(Valo666 @ May 30, 2007 - 5:03 PM) [snapback]563068[/snapback]
IIRC the original speakers are 20cm, you'll just have to try them i think. If they don't work out, you might have to make a ring out of MDF or something, fix the speaker to that, then screw that to the housing.
post May 30, 2007 - 5:23 PM
Valo666
Joined May 15, '05
From Toronto
QUOTE(manphibian @ May 30, 2007 - 5:20 PM) [snapback]563072[/snapback]
are they mounted with 3 bolts? or 4??..these adaptors use 3 bolts.
post May 30, 2007 - 5:26 PM
manphibian
Joined Oct 13, '06
From UK
Not looking good for the adaptor, they have 4 screws holding them in kindasad.gif
This post has been edited by manphibian: May 30, 2007 - 5:26 PM
post Jun 6, 2007 - 3:00 PM
tomazws
Joined Oct 30, '04
From So Cal
QUOTE(Valo666 @ May 30, 2007 - 2:31 PM) [snapback]563058[/snapback]
Bryan
Did it work?
post Jun 6, 2007 - 4:36 PM
Valo666
Joined May 15, '05
From Toronto
didnt get around to it..lol. Im gonna do it sometime soon when i get free time.
post Jun 6, 2007 - 6:28 PM
tomazws
Joined Oct 30, '04
From So Cal
QUOTE(Valo666 @ Jun 6, 2007 - 2:36 PM) [snapback]565743[/snapback]
I forgot who posted a link in the forum regarding a adapter specified for the 90-99 Celica 8" hole
Here's the link: http://www.mjmautoinnovations.com/sak825t65.htm
post Jun 6, 2007 - 9:26 PM
Valo666
Joined May 15, '05
From Toronto
thanks man.
post Jun 7, 2007 - 1:58 AM
Racer_J
Joined May 16, '07
From Newcastle UK
QUOTE(Valo666 @ Jun 6, 2007 - 10:36 PM) [snapback]565743[/snapback]
When you do get round to it, PM me to let me know how it went. I've gotta get round to doing the same job on my car. I'm a bit worried about re-fitting my door panels though cos they never seem to go back properly!
post Jun 7, 2007 - 2:30 AM
manphibian
Joined Oct 13, '06
From UK
Don't worry bout the panels, there are loads of screws to hold it in place. It won't rattle.
Bit off-topic but i changed my rears yesterday with THESE Awesome! massive difference in clarity.
post Jun 8, 2007 - 1:50 AM
Racer_J
Joined May 16, '07
From Newcastle UK
QUOTE(manphibian @ Jun 7, 2007 - 8:30 AM) [snapback]565988[/snapback]
Cheers mate,
I've gotta get it done soon, my front left speaker sounds as gritty as hell at any decent volume and it's driving me nuts! Think i'll do what you've done and get some 20cm drivers for the front doors, that should sound pretty sweet I reckon.
post Jun 9, 2007 - 9:39 PM
6strngs
Joined May 12, '06
From Wilmington, NC
so 16cm speakers bolt right up to the rear brackets? is a 16cm the same as a 6.5 inch?
post Jun 25, 2007 - 5:47 PM
Valo666
Joined May 15, '05
From Toronto
so progress, i finaly got aorund to measuring the speaker mounts, and the ones i have posted up top, go up to 7 3/4", aka 19.86CM, so they might work. So either tonight or tomorrow im gonna strip the door skins off and try and see if they mount up.
post Jun 26, 2007 - 12:37 AM
soven
Joined Mar 14, '05
From Auckland,New Zealand
just remember that if they dont... all you have to do is either buy one of those plastic chopping boards or 9mm mdf wood and arm yourself with a drill and jigsaw.
post Jun 26, 2007 - 1:32 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(6strngs @ Jun 9, 2007 - 7:39 PM) [snapback]566748[/snapback]
still waiting for an answer...
post Jun 26, 2007 - 11:12 AM
Racer_J
Joined May 16, '07
From Newcastle UK
QUOTE(6strngs @ Jun 26, 2007 - 7:32 AM) [snapback]572169[/snapback]
divide 16 by 2.54...
That'll be 6.299 inches then.
post Jun 26, 2007 - 11:33 AM
94celigts
Joined Jun 13, '07
From Whitby, ON, CAN
I dont know about you guys but the first time i took off my door panels it was in the winter, and i had a hell of a time getting them back on at the top, The next time i did it it was in the summer and i had the windows down, Much easier goes in no trouble, i suggest any door mods taking off the panel try it with the windo dow it makes for an easier time when replacing it. Just to let you guys know, i didnt know if anyone has figured this out before me
Lo-Fi Version Time is now: February 20th, 2025 - 1:18 AM
