Enthusiast ![]() Joined Jan 18, '06 Currently Offline Reputation: 0 (0%) ![]() |
how do you start removing the rear speakers? help please? lol
![]() Enthusiast ![]() ![]() ![]() Joined Feb 23, '07 From Albany, NY Currently Offline Reputation: 3 (100%) ![]() |
-uh, take out the grill with a flat head screwdriver
-there is a bolt or screw in there somewhere that you have to take out -lower the back seats and take out the screws holding the black panel then pry the big black panel off -there are 3 bolts on the speaker housing, 2 at the top and 1 at the bottom, remove those -there is a wire running to a clip at the bottom of the whole housing, remove the clip with the wires, then the whole housing should come out -the rest is easy, just splice and solder the speaker wires and mount the speaker -reverse the directions to put everythign back together |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) ![]() |
QUOTE(Redline08 @ Jun 2, 2007 - 4:51 PM) [snapback]564150[/snapback] -take out the grill with a flat head screwdriver -there is a screw in there that you have to take out -lower the back seats - lift up the carpet on the bottom of the seat - remove the two bolts on either side - remove the seat from car - take the bottom part of the seat out simply by pulling it up and out - there will be a bracket on the paneling w/ two 10mm bolts, remove them. - where the seat would have been w/ it up there are two screws and one fastener, take out the screws - the fastener, you 'unscrew it' a little, and then you'll be able to simply pull it out - where the bottom of the seat was, there will b a screw also, take that out too - remove the trim from under the door(where it would be when its closed) - the panel should now come off pretty easily -there are 3 bolts on the speaker housing, 2 at the top and 1 at the bottom, remove those -there is a wire running to a clip at the bottom of the whole housing, remove the clip with the wires, then the whole housing should come out -the rest is easy, just splice and solder the speaker wires and mount the speaker -reverse the directions to put everything back together better than prying it off.. save you some pain and suffering ![]() w/ the carPC in this area behind the speaker (see my profile pics) i have to access this area a lot. good luck w/ your install! -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
lol, yea way btter than prying it off, i guess i was just lazy when i did mine...
hah o well good luck |
Lo-Fi Version | Time is now: February 18th, 2025 - 7:20 PM |
