4 Pages V  < 1 2 3 4 >
> Did my Valve Cover Gasket, Finally!
post Jun 3, 2007 - 5:44 PM
great job!
post Jun 3, 2007 - 7:36 PM
m0dd3d1
Joined Jan 30, '06
From Augusta, GA
Thanks Devilsden! So has anyone done/thought about painting the intake manifold? Or would it get too hot? It just looks like it'd look really good in your bay if it was red as well!
Hopefully I can accomplish this without any hitches...hopefully. Otherwise I'll be one of the guys on here with a "OH SH**, PLEASE HELP" thread, again. smile.gif
1998 Toyota Celica GT
2007 Subaru Impreza WRX STi
2007 Toyota Tacoma 4x4
1974 Datsun 260Z
1997 Subaru Legacy L Wagon
post Jun 3, 2007 - 7:40 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
QUOTE(m0dd3d1 @ Jun 3, 2007 - 8:36 PM) [snapback]564532[/snapback]
the manafold is SOOOOO hard to get to, and to unbolt, its easier to remove the engine from the bay, and remove it...the bolts are on the back of the head, so theres little space between the firewall, and the motor. ITs just tuff, thats y most dont bother. If u have your motor pulled, id go for it, if not....dont waste your time.
If u do have any problems, seriously, pm me. ill offer any insight i can.
Kawi Love
post Jun 3, 2007 - 10:40 PM
CaliJeff
Joined Apr 22, '07
From Bay Area, California
So it IS totally necessary to get a new gasket when u do this ?
You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=-
post Jun 3, 2007 - 10:43 PM
devilsden97
Joined Jun 13, '05
QUOTE(CaliJeff @ Jun 3, 2007 - 11:40 PM) [snapback]564573[/snapback]
to paint it? No
i was replacing my gasket fromt he start. (it had a small leak) so while i had it off, i figured y not paint it.
Edit: If i knew so many people woulda been interested in this, i woulda taken more photos of the process, and try to put a DIY/how to, together.
This post has been edited by devilsden97: Jun 3, 2007 - 10:44 PM
Kawi Love
post Jun 3, 2007 - 10:54 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
You can paint anything on the engine... The valve cover gets hotter than the intake plenum. Its not THAT hard to remove either. I even paint the exhaust manifold heat shields with the 1200?degree paint and it holds up fine smile.gif
post Jun 4, 2007 - 10:28 AM
CaliJeff
Joined Apr 22, '07
Sounds good. So for the valve cover i should just clean it first, then perhaps sand it with 400 grit? then spray it ?
post Jun 4, 2007 - 11:31 AM
devilsden97
Joined Jun 13, '05
i cleaned mine with some engine degreaser, let it dry, then just sprayed it, the cover is pretty course, so it should stick fine.
Kawi Love
post Jun 4, 2007 - 12:13 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(devilsden97 @ Jun 4, 2007 - 9:31 AM) [snapback]564727[/snapback]
when I did mine, I also cleaned it with engine degreaser, but then I sprayed it with duplicolor engine primer before the color spray. It ended up coming out alot better than my friend's valve cover we did the day before using only a color coat.
post Jun 4, 2007 - 3:04 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Good job Miguel. I happy to see you working on the car. The valve cover looks great, you should paint the heat shield hi temp black. That valve cover looks a little lonely now.
I will return one day.
post Jun 4, 2007 - 3:33 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
post Jun 5, 2007 - 3:19 PM
devilsden97
Joined Jun 13, '05
QUOTE(Defgeph @ Jun 4, 2007 - 4:04 PM) [snapback]564852[/snapback]
I think i have my next project...lol
the 5sfe's exaust manifold doesnt get hotter then 1200°F right? Also, i didnt clear coat my valve cover, and ive heard some people say its going to start chipping..any insight on that? Should i clear cloat the exaust manifold heat shield then?
Kawi Love
post Jun 6, 2007 - 2:23 PM
laff09
Joined Jul 28, '06
From Delaware
Anyone elses valve cover a SOB to get off? I removed the acorn nuts, and the manual says to "remove" the valve cover. Easier said than done, I don't want to pry it off and damage the head/cover mating surface, and i punctured the seal, theres got to be something im missing? Any tips for removing teh actual valve cover?? 7afe btw
post Jun 6, 2007 - 2:58 PM
Valo666
Joined May 15, '05
From Toronto
Migga, b4 u did the valve cover gasket, did you have any oil coming into your sparkplug tubes or on your plugs?? Im trying to figure out where i got a leak from and i think it might be from the cover or the tube seals.
post Jun 6, 2007 - 3:01 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
Good job, brother. Hey, why does the 5S lean back like a gangsta? tongue.gif
post Jun 6, 2007 - 3:06 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(OOBE @ Jun 6, 2007 - 1:01 PM) [snapback]565694[/snapback]
because it's too big to fit in the bay otherwise.
post Jun 6, 2007 - 3:16 PM
devilsden97
Joined Jun 13, '05
QUOTE(laff09 @ Jun 6, 2007 - 3:23 PM) [snapback]565672[/snapback]
that where the rubber mallet came into play. I beat it a little bit, and it should break loose.
QUOTE(Valo666 @ Jun 6, 2007 - 3:58 PM) [snapback]565690[/snapback]
it was leaking on the passengerside/down the side facing the firewall (that corner) i did have oil in my #3 cylinder, it was VERY slight, i figure someone spilled some oil on the top, and it just pooled there. The valvecover doesnt seal the tubes that connect the spark plug wires to the spark plug to the cylinder itself (if that made sense. I can show u at DWG if ud like.
Kawi Love
post Jun 6, 2007 - 5:22 PM
laff09
Joined Jul 28, '06
From Delaware
Thanks, I *forgot* to take off the washers..thatd appeared to be part of the valve cover itself LOL, after that it came off pretty easily. Waiting for the paint to dry now ebfore i put her back in.
post Feb 3, 2008 - 3:06 PM
Celicav
From Virginia
kindasad.gif Alright, so I finally decide to take this painting project on today and replace the valve cover gasket. BUT one SOB step I don't think has been mentioned (unless I missed it!) is that you have to unfasten that damn black plastic cover that sits between the timing belt cover and the left edge of the valve cover. This plastic cover sits over the bottom lip of the valve cover and it took me quite a while to figure out the right screws (there are two) to unhatch to loosen that plastic cover up in order to get the valve cover lip to clear (the screw closer to the fire wall is harder to get to). There are two screws you just have to loosen up on the black plastic cover, then you have to take off two other bracket screws associated with the tube that connects between this cover and the alternator.
I will post pics up later this week when I am all finished. My valve cover is drying at the moment...I painted it the high gloss black smile.gif
post Feb 3, 2008 - 5:35 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Celicav @ Feb 3, 2008 - 12:06 PM) [snapback]637542[/snapback]
for some reason, it seems some celicas have these screws and others don't. mine didn't.
Lo-Fi Version Time is now: November 29th, 2024 - 3:56 AM
