> hatch will not open, tricks anyone?
post Jun 3, 2007 - 9:50 PM
slvr_celica_GT_8...
Joined Jul 18, '06
From plymouth, MA USA
this could be considered interior also i guess but anyways, my cars hatch wont open, the key will not work and the lever in the car wont pop it, i think the cale is snapped/broken so i have no way of opening my cars hatch the key wont turn when i put it in the hatch either, is there anyway i can open my hatch or fix the lever/key slot, or some kinda trick to pop it open some how, thanks hope one of u guys know thanks, kevin
IPB ImageIPB ImageIPB Image
post Jun 3, 2007 - 11:20 PM
Starcraftjunkie
Joined Nov 21, '05
From Wpg, MB. Canada
The cable is probably snapped. You'll have to access the lock mechanism from the back seats. The trim will have come off, and there is a chance you'll damage it in the process.. but you gotta get the trim off to get at the cable.
best of luck.
post Jun 4, 2007 - 7:19 AM
behindthesmile
Joined Jul 31, '05
From toronto
had that problem bef. makesure your using the master key cause theres a safety lock feature in our cars that only the master key can unlock check your lock first if its the key hole looks like this (-) then most likely you safety locked it but if the key hole is like this (l) then the problem is something else
I've learned my lesson... the best mod you can have for your car is a good alarm system
post Jun 4, 2007 - 11:21 AM
slvr_celica_GT_8...
Joined Jul 18, '06
thanks, ill have to look at it i have a system in the hatch so it gunna be tuff trying to pry open the platic in the back and look at that cable
post Jun 4, 2007 - 6:16 PM
tomazws
Joined Oct 30, '04
From So Cal
QUOTE(behindthesmile @ Jun 4, 2007 - 5:19 AM) [snapback]564665[/snapback]
Our cars have different kinds of keys!?!??!
post Jun 4, 2007 - 6:37 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
QUOTE(tomazws @ Jun 4, 2007 - 7:16 PM) [snapback]564928[/snapback]
I think 1 key is the master key, 2nd key is the Valet key that will only open doors and turn the ignition on.
FlickR
post Jul 1, 2007 - 11:26 AM
dutchboy
Joined Jun 28, '07
lift up on the trunk lip while you turn the key. This works for me. The hatch is so heavy that the equipment just can't handle it. Hopefully once I get new struts on there it will pop up by itself!
post Jul 2, 2007 - 1:20 AM
CelicaST_CALI
Joined Feb 28, '07
BANNED. for life, you moron.
Lo-Fi Version Time is now: January 9th, 2025 - 1:12 AM
