2 bar map sensor |
2 bar map sensor |
Jun 8, 2007 - 10:50 PM |
Enthusiast Joined Mar 23, '06 From Nashville Tennessee Currently Offline Reputation: 5 (100%) |
EDIT>
First post.. this a quote from a local guy when i asked him about the supras map sensor. "MKIV's dont really have MAP sensors. They run on a MAF from the factory, but they do have a "turbo pressure sensor" that doesnt do anything other than tell the ECU when it overboosts." Is that what im looking for? This post has been edited by Shocker: Jun 10, 2007 - 5:17 PM -------------------- |
Jun 9, 2007 - 1:24 AM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
QUOTE(Shocker @ Jun 8, 2007 - 8:50 PM) [snapback]566550[/snapback] Like the title say im looking for a 2bar map sensor.For my turbo set up. you'll probably have better luck posting on the forums at mr2oc.com or alltrac.net -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jun 9, 2007 - 3:59 PM |
i'd use ebay and grab a supra one.
the mr2 only had it on that 3rd gen, so they ask like 200 the 2jz used map in japan, and the 1jz uses map since most people want to be able to run more than 14-18psi, they upgrade, so they got for cheaper you owe me, biach -------------------- |
Jun 9, 2007 - 4:09 PM |
Enthusiast Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
All 3sgte (1st, 2nd, and 3rd gen) have MAP sensor even though the 1st and 2nd gen doesn't use the sensor for the purpose of fueling like in the speed density system on the 3rd gen. You can find a used one from 2nd gen on MR2OC and alltrac.net
-------------------- _Gary
Jun 9, 2007 - 4:43 PM |
QUOTE(Consynx @ Jun 9, 2007 - 3:59 PM) [snapback]566691[/snapback] i'd use ebay and grab a supra one. the mr2 only had it on that 3rd gen, so they ask like 200 the 2jz used map in japan, and the 1jz uses map since most people want to be able to run more than 14-18psi, they upgrade, so they got for cheaper you owe me, biach Yea i do..I think ill go take the one out of my moms SC300,,Not. Thanks for the help. -------------------- |
Jun 9, 2007 - 5:46 PM |
Also is the 2 bar map sensor compatable with OBDII.?
I found a map sensor from a 94 twin turbo supra. -------------------- |
Jun 9, 2007 - 9:21 PM |
yeah it'll work with OBDII. and yeah, you can use the one from a 2nd gen 3sgte such as an mr2.
Jun 10, 2007 - 9:41 AM |
"MKIV's dont really have MAP sensors. They run on a MAF from the factory, but they do have a "turbo pressure sensor" that doesnt do anything other than tell the ECU when it overboosts." Is that what im looking for? Mods could you maby move this into the forced induction. Now that it becoming a discussion. -------------------- |
Jun 10, 2007 - 10:37 AM |
Yes, the MKIV run on MAF, not speed density (MAP based)
However, similar to 1st and 2nd gen 3sgte, they do have "turbo pressure sensor" for fuel cut and what not. (the only different is that 1st and 2nd gen 3sgte use VAM not MAF sensor) Toyota call it "turbo pressure sensor", but it is actually a "MAP sensor" BTW, SC300 (or IS300) does not have what you need. It is 1JZGE, not 1JZGTE. (2JZGE in IS300) So it has "vacuum sensor" instead of "turbo pressure sensor" This post has been edited by Gary: Jun 10, 2007 - 10:38 AM -------------------- _Gary
Jun 10, 2007 - 10:41 AM |
So this wouldnt be helpful to me?
This..No good? -------------------- |
Jun 10, 2007 - 11:09 AM |
Enthusiast Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
QUOTE(Shocker @ Jun 8, 2007 - 10:50 PM) [snapback]566550[/snapback] Like the title say im looking for a 2bar map sensor.For my turbo set up. You should put this in the Buying/Selling section |
Jun 10, 2007 - 11:20 AM |
QUOTE(mr2oc.com) It needs to be the MAP sensor from a gen II 3sgte. If in doubt check the part number on the MAP sensor itself. 2bar MAP SENSOR(factory 3s) Part # 84420-17030 If I remember correctly it is not a standard 2 bar MAP sensor and the one from the gen III is not the same either. EDIT: it might also be the part number 89420-17030 This post has been edited by 6strngs: Jun 10, 2007 - 11:21 AM -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jun 10, 2007 - 5:15 PM |
QUOTE(toyotacrazy @ Jun 10, 2007 - 11:09 AM) [snapback]566858[/snapback] QUOTE(Shocker @ Jun 8, 2007 - 10:50 PM) [snapback]566550[/snapback] Like the title say im looking for a 2bar map sensor.For my turbo set up. You should put this in the Buying/Selling section I had it moved from the buying selling section to here since it became a nice little discussion. If it makes you feel better ill change my first post. -------------------- |
Jun 10, 2007 - 5:19 PM |
So would i be able to use this sensor...
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...1298&rd=1,1 cant find one from the older mr2. -------------------- |
Jun 10, 2007 - 10:36 PM |
anybody? i know im seeming a bit impatiant but id really like to know..
Jun 11, 2007 - 12:17 AM |
Enthusiast Joined Aug 23, '05 From Princeton, Minnesota Currently Offline Reputation: 7 (100%) |
its just a 2bar MAP sensor / turbo pressure sensor off of a 2nd gen MR2 with a 3sgte. MR2OC is crawling with them just post up a WTB and youll get one. i got mine for 85 shipped from there.
-------------------- -Brian
Jul 3, 2007 - 2:46 PM |
and when i said mkiv supra i meant the jdm one
US Spec runs a MAF sensor and 550cc's JDM Spec runs a MAP and 440cc's there's a bunch of these 1j and 2j sensors for sale @ Supramania right now, iunno why all of a sudden so many are avail, when i needed one there were 0 for sale. -------------------- |
Jul 3, 2007 - 3:42 PM |
just to let you know, I just installed my turbo kit, and I used the 2nd gen mr2 turbo sensor and the wiring harness plugs right into it and it works great!
Lo-Fi Version | Time is now: November 29th, 2024 - 10:53 AM |
