5 Pages V  < 1 2 3 4 > »
> The long awaited transformation, 1 car 1 decade 1 dream
post Jun 9, 2007 - 10:40 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
QUOTE(tonytutino @ Jun 9, 2007 - 11:34 PM) [snapback]566766[/snapback]
good god that'll be amazing dude
lol, i know just how you feel about the wind raping the packing peanuts....
the same thing happened when my hood came in from greyhound, the box wouldnt fit in my truck so i had to take it out and man stuff went everywhere, newspapers, peanuts, towels? (ask celiracer, he packed it lol)
Yeah I really pissed off my neighbors it flew down like 10 or 12 houses....then it rained! The east coast hates me!
post Jun 9, 2007 - 11:01 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
I would love to get one of these dropped off at my front door, I wouldn't care if peanuts covered the whole neighborhood!
post Jun 9, 2007 - 11:14 PM
laff09
Joined Jul 28, '06
From Delaware
mm, thats beefy
post Jun 10, 2007 - 6:00 AM
m0dd3d1
Joined Jan 30, '06
From Augusta, GA
So...what exactly are you doing with your engine? And is that pic of the inside stripped what it looks like now?
This post has been edited by m0dd3d1: Jun 10, 2007 - 6:00 AM
1998 Toyota Celica GT
2007 Subaru Impreza WRX STi
2007 Toyota Tacoma 4x4
1974 Datsun 260Z
1997 Subaru Legacy L Wagon
post Jun 10, 2007 - 12:44 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
I want to do the turbo 1uzfe, but the shop doing the work is trying to sell me on a LS1. The car as of now is gutted like the pics, with just a few more things removed.
Any opinions on what motor I should base this off of?
Check out this beast...
This post has been edited by coldbluesteel: Jun 10, 2007 - 12:48 PM
post Jun 10, 2007 - 1:00 PM
manphibian
Joined Oct 13, '06
From UK
Awesomeness!
but man i hope you scooped up all those peanuts, looks like you're gonna have to store that bumper for a WHILE laugh.gif
post Jun 10, 2007 - 1:06 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
Yeah I'm not even concerned with the exterior right now, just want to get all the mechanical issues worked out. Plus there is going to be a lot of cutting and welding needed so no point of trying to fit sheet metal yet.
post Jun 10, 2007 - 3:12 PM
massbrandon
Joined Mar 6, '06
From massachusetts
woot.gif thanks for posting the pics man. You've got some great plans going on. I hope everything goes well for ya.
post Jun 10, 2007 - 3:18 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
QUOTE(massbrandon @ Jun 10, 2007 - 4:12 PM) [snapback]566902[/snapback]
Yep gotta love severance pay!
post Jun 10, 2007 - 3:38 PM
milnersXcoupe
Joined Jun 10, '07
From new=HUDSON VALLEY=york
-Wikipedia quote-
The 1GR-FE is the 4.0L version. Bore is 94 mm and stroke is 95 mm [3.7"]
Output is 236 hp (183 kW) at 5200 rpm with 266 lb-ft (382 Nm) of torque at 4000 rpm on 87 octane, and 239 hp at 5200 rpm with 278 lb-ft at 3700 rpm on 91 octane.
This engine features Toyota's single VVT-i, variable valve timing, system and a compression ratio of 10.0:1.
Inside, the 1GR uses a taper-squish combustion chamber design with matching pistons to improve anti-knocking and engine performance, while also improving intake and fuel efficiency.
Toyota adopted a siamese-type intake port, which reduces the surface area of the port walls and prevents fuel from adhering to such walls.
This engine has special cast-iron cylinder liners cast into the block, which are a spiny type to improve adhesion between the liner and cylinder block.
With these special thin liners it is impossible to bore the block. In the event of cylinder wall damage (scoring, deep protrusions, etc), the entire cylinder block must be replaced.
For increased block rigidity, the 1GR also receives a high temperature plastic insulator/protector, which fills the empty space between the outer portion of the cylinders and block material common to open deck engines.
For increased cooling efficiency, the 1GR employs water passages between the bores of the engine.
[ the 5.7 hs Siamese'd cylinder sleeves ]
There are such 2 passages for each bank for a total of 4.
This reduces cylinder hot-spotting and keeps combustion chamber temperatures more uniform.
-end quote-
Factory Supercharged version will pump out 335HP.
This is a Perfect candidate for a Turbo in a 6G Sports Fans !
This engine is 0.32" shorter on stroke than the Tundra 5.7 of 4.02" AND weighs 384 lbs.
GT - " '99.....In the Shade"
post Jun 10, 2007 - 4:13 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
Much better support, and potential for these...
Toyota UZ engine
From Wikipedia, the free encyclopedia
Jump to: navigation, search
Toyota UZ
Manufacturer Toyota Motor Company
Production 1989–
Class DOHC 90° V8
The Toyota UZ engine family is a 32-valve quad-camshaft V8 piston engine series used in Toyota's luxury offerings and sport utility vehicles.
Contents
[hide]
* 1 1UZ-FE
* 2 2UZ-FE
* 3 3UZ-FE
* 4 See also
[edit] 1UZ-FE
The all-alloy 1UZ-FE debuted in 1989 in the first generation Lexus LS400/Toyota Celsior with an output of 191 kW (256 hp) and torque of 353 N·m (260 ft·lbf). The engine was progressively released in a number of other models across the Toyota/Lexus range and proved to be a strong, reliable and smooth powerplant with features such as 6-bolt main bearings and belt-driven quad-camshafts.
Initially running 10:1 compression, the engine was slightly revised in 1995 with lighter conrods and pistons and an increased compression ratio to 10.4:1 resulting in peak power of 195kw and torque of 363nm.
In 1997, Toyota's VVT-i variable valve timing technology was introduced along with a further CR increase to 10.5:1 bumping power and torque to 216 kW (290 hp) and 407 N·m (300 ft·lbf).
The 1UZ-FE was voted to the Ward's 10 Best Engines list for 1998 through 2000.
Applications:
* 1989-2000 Lexus LS 400/Toyota Celsior
* 1990-2002 Toyota Crown
* 1991-2000 Lexus SC 400/Toyota Soarer
* 1992-2000 Lexus GS 400/Toyota Aristo
* Toyota MR2 Le Mans Car
See also:
* Ward's article
[edit] 2UZ-FE
The 2UZ-FE is a 4.7 L cast iron block version built in Tahara, Aichi, Japan and at Toyota Motor Manufacturing Alabama. Designed for low-revving, high-torque SUV applications, it's bore is 94 mm and stroke is 84 mm. Output is 179 kW (271 hp) at 4800 rpm with 427 N·m (315 ft·lbf) of torque at 3400 rpm. Like the 1UZ-FE it has aluminium DOHC cylinder heads, MFI fuel injection, 4 valves per cylinder with bucket tappets, one-piece cast camshafts, and a cast aluminium intake manifold.
Applications:
* 2001-2005 Toyota Land Cruiser
* 2001-2005 Lexus LX 470
* 2001-2003 Toyota Tundra
* 2001-2003 Toyota Sequoia
Another 2UZ-FE variation adds VVT-i and electronic throttle control.
Applications:
* 2004 Toyota Tundra
* 2004 Toyota Sequoia
* 2004 Lexus GX 470
* 2005 Toyota 4Runner
[edit] 3UZ-FE
The 3UZ-FE is a 4.3 L (4292 cc) version built in Japan. Bore is 91 mm and stroke is 82.5 mm. Output is 216 to 224 kW (290 to 300 hp) at 5600 rpm with 441 N·m (325 ft·lbf) of torque at 3400 rpm. It has an aluminum engine block and aluminum DOHC cylinder heads. It uses SEFI fuel injection, has 4 valves per cylinder with VVT-i. A version of this engine is used in Toyota's Super GT race cars.
Applications:
* Lexus LS 430
* Lexus GS 430
* Lexus SC 430/Toyota Soarer
* Super GT
o Toyota Supra GT500 Race Car
o Lexus SC 430 GT500 Race Car
post Jun 10, 2007 - 11:07 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
to make ur goals..... 10k wont be close
post Jun 10, 2007 - 11:09 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
QUOTE(dustin15brown @ Jun 11, 2007 - 12:07 AM) [snapback]567019[/snapback]
? What do you think it will take?
What are you doing with the Z? How much are you investing in that?
This post has been edited by coldbluesteel: Jun 10, 2007 - 11:11 PM
post Jun 11, 2007 - 12:04 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
People that make over 700 WHP usually spend at least $15,000- $20,000. It doesn't matter if it's a Civic or a Supra, the money spent is a lot.
post Jun 11, 2007 - 2:24 AM
C3L1CA
Joined Mar 11, '04
From Oakdale, MN
With a ton of power it will be a challenge to actually put it down with fwd. Sounded like you might go rwd or something, which would be pretty sweet but lots of money.
http://www.atsracing.net/550whpbuildup.htm
A nice list to make your 3sgte have at least 550whp biggrin.gif Just to show to go fast it takes a lot of money
-Brad
01 a4: daily
post Jun 11, 2007 - 3:30 AM
celicaST
Joined Jun 23, '05
do the 1uz! if you want to keep save money and swap it fwd check this out
http://mr2oc.com/showthread.php?t=193652
he has a custom adapter and flywheel for sale to mate the 1uz to the e153 tranny. these are the 2 main parts needed and they have to be made custom. if the engine fits, it shouldnt be much more difficult than any other swap. would just have to fabricate a passenger side mount which is no big deal, and the exhaust might be a pain to route. looks like you got an awesome project on your hands. looking forward to see it come together thumbsup.gif
post Jun 11, 2007 - 1:25 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
Most definitely doing RWD conversion. It would be pointless to try to put that much power through FWD. I am building to 400 to 500 RWHP.... at first! The 1u and ls1 are comparable when you look at cost per HP/ Torque, and don't forget the LS1 is 5.7 while the 1u is only 4.0. They are both excellent choices!
post Jun 11, 2007 - 1:30 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
[/quote]
This looks bulletproof, but I crave the V8 torque curve! There are a ton of LS1' running this kind of power with just a few mods, and I were to turbo it... biggrin.gif The 1u would take more to build that power, but it is like 5 to 10x times less $ initially.
post Jun 11, 2007 - 6:12 PM
root
Joined Feb 26, '06
From Bowling Green, OH
Off the engine convo, but still on this thread.....what front lip is that? Flippin schweetness biggrin.gif
post Jun 11, 2007 - 6:21 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
QUOTE(root @ Jun 11, 2007 - 7:12 PM) [snapback]567334[/snapback]
Thanks. It's a custom 404 lip off a regular gt. Lot's of shaving to make it fit... still not 100%.
Lo-Fi Version Time is now: December 2nd, 2024 - 4:34 AM
