> need help...
post Jun 11, 2007 - 6:05 PM
miro1975
Joined Nov 23, '05
From Charleston, WV
My steering wheel moved to the right after last autocross. Cars alighment is fine. I just did that last week. Car drives perfect, just steering wheel is moved. I changed a busing on the right side of the steering rack, what holds it and that did not help. There is another bushing on the left side. Should I change that one also. Anybody out there who knows what is going on?
post Jun 11, 2007 - 7:10 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
did you hit anything or run over a pothole lately?
post Jun 11, 2007 - 7:23 PM
miro1975
Joined Nov 23, '05
From Charleston, WV
No. It's that I hit anything. It hepened 3th time just on autocross. G-force is pretty high out there...
Does anybody have a detailed diagram or picture of a steering rack and pinion? I just need find out about that second bushing. Thanks...
post Jun 13, 2007 - 2:51 AM
Racer_J
Joined May 16, '07
From Newcastle UK
Even though your car drives straight and the alignment is OK as you put it, you should get it done again only make sure the steering wheel is centred. I had the same problem, got the alignment or tracking done and my steering wheel was off centre so I took it back got them to do it again properly.
Lo-Fi Version Time is now: November 28th, 2024 - 12:38 PM
