clinking sound? |
clinking sound? |
Jun 11, 2007 - 8:38 PM |
Enthusiast Joined Jun 8, '07 From Houston, Texas Currently Offline Reputation: 1 (100%) |
I was just test driving my new 94 GT and it makes a clinking sound that comes from the front left wheel area. Sounds like something might be loose in brakes or suspension. Anyone have an idea? Thx
Jun 11, 2007 - 9:12 PM |
if it makes a noise when u turn its a cv joint, makes noise when driving, making a wheel bearing, pulls to one side while braking then a wraped rotor
Jun 11, 2007 - 9:32 PM |
It makes the noise when I drive over bumps. Even little ones. How hard is it to change the wheel bearing?
Jun 11, 2007 - 9:41 PM |
parts are reasonable, labor is what kills....might be a strut mount?
This post has been edited by LewFX: Jun 11, 2007 - 9:41 PM -------------------- |
Jun 11, 2007 - 10:20 PM |
Well is it something I could do or would a pro have to do it?
Jun 11, 2007 - 11:07 PM |
Enthusiast Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
you have drop springs on? If so, the strut mount wasn't greased or installed properly. As far as fixing it yourself, it's pretty simple. Best way is to get a Chilton's or Haynes service manual. It has how-to and torque specs so you don't overtighten anything.
This post has been edited by netrata: Jun 11, 2007 - 11:07 PM -------------------- |
Jun 11, 2007 - 11:39 PM |
How do I know what kind of springs? Sorry I'm new to all this. Ill pick up one of those manuals asap.
Jun 12, 2007 - 3:56 AM |
It doesn't really matter what color the spring is. Just take a look at your car, does it look like it was lowered like an inch or two?
Jun 12, 2007 - 9:24 AM |
nope not at all, infact that is something I want to do. maybe i can fix it when i get it dropped
Jun 12, 2007 - 12:12 PM |
Ok, then it's like what LewFX said. Possibly bad upper strut mounts. Might as well order all 4 and replace it when you lower your car.
Jun 13, 2007 - 1:25 AM |
Could even be your sway bar bushings worn. Check it.
Jun 13, 2007 - 1:36 PM |
the mechanic found it, a bolt was missing from one of the calipers (splg?) on that wheel. I believe he fixed it.
Lo-Fi Version | Time is now: December 1st, 2024 - 4:03 AM |
