Enthusiast ![]() ![]() Joined Oct 19, '02 From Spring Valley, NY Currently Offline Reputation: 1 (100%) ![]() |
what type of maintenance should i be doing?? i can name some of the basics...can you guys help me out on what i left out...PLEASE...
ohh yeah i have a 97 ST automatic Need: Spark Plugs Cap and Rotor Wires PCV Valve Timing Belt, water pump, tensioner Flush Coolant Flush power steering fluid(how hard is this?? or should i take it to a shop??) Transmission Oil Change Done: Drive belts(AC, powersteering, and alternator) Upper and lower radiator hose Thermostat Fuel filter Valve cover gasket This post has been edited by Ve1Ls1dEvolutioN: Jun 13, 2007 - 8:50 PM |
anyone?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) ![]() |
inspect all the hoses and replace ones that need replacing
check the battery terminals for corrosion and clean if necessary inspect and the rotate or replace the tires if needed ispect your brake pads and replace (along with resurfacing the rotors) if necessary air filter inspect your axle boots replace fuel tank cap gasket adjust valve clearances inspect the exhaust for leaks inspect your steering and suspension systems maybe pull you throttle body and EGR off and clean any carbon build out of them plus all the other stuff you said. -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
how do i clean the corrossion on my battery?? what do i use??
how hard is it to change the axle boots?? any how to on removing EGR?? dont even know where its located thanx for your reply |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 28, '03 From Bloomington, IN Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(6strngs @ Jun 17, 2007 - 6:21 AM) [snapback]569221[/snapback] inspect all the hoses and replace ones that need replacing check the battery terminals for corrosion and clean if necessary inspect and the rotate or replace the tires if needed ispect your brake pads and replace (along with resurfacing the rotors) if necessary air filter inspect your axle boots replace fuel tank cap gasket adjust valve clearances inspect the exhaust for leaks inspect your steering and suspension systems maybe pull you throttle body and EGR off and clean any carbon build out of them plus all the other stuff you said. Very nice write-up. Sounds like you are a tech who done his fair share of PMI's. If not, sounds like you'd make a great entry level tech. -------------------- NASA/SCCA RX-7....currently under the knife
92 Civic hatch B16 - Sold 10th anniv RX-7 - RIP The Slow Celica - Sold...and then crushed crushed due to street racing. Quote from Seinfeild: George's Boss reading a magazine: "People magazine's most beautiful people. Oh and a Celica...nothin wrong with that!" |
QUOTE(SlowCelica94 @ Jul 11, 2007 - 11:01 PM) [snapback]577672[/snapback] QUOTE(6strngs @ Jun 17, 2007 - 6:21 AM) [snapback]569221[/snapback] inspect all the hoses and replace ones that need replacing check the battery terminals for corrosion and clean if necessary inspect and the rotate or replace the tires if needed ispect your brake pads and replace (along with resurfacing the rotors) if necessary air filter inspect your axle boots replace fuel tank cap gasket adjust valve clearances inspect the exhaust for leaks inspect your steering and suspension systems maybe pull you throttle body and EGR off and clean any carbon build out of them plus all the other stuff you said. Very nice write-up. Sounds like you are a tech who done his fair share of PMI's. If not, sounds like you'd make a great entry level tech. wow, thanks! I'm not a tech though. in fact, I'm only 17 and this is my first car. but I'm taking classes and hope to have an AS degree in automotive technology in two years and then be a mechanic after that. so that means a lot to me. ![]() This post has been edited by 6strngs: Jul 12, 2007 - 3:10 AM -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
QUOTE(6strngs @ Jul 12, 2007 - 8:10 AM) [snapback]577705[/snapback] QUOTE(SlowCelica94 @ Jul 11, 2007 - 11:01 PM) [snapback]577672[/snapback] QUOTE(6strngs @ Jun 17, 2007 - 6:21 AM) [snapback]569221[/snapback] inspect all the hoses and replace ones that need replacing check the battery terminals for corrosion and clean if necessary inspect and the rotate or replace the tires if needed ispect your brake pads and replace (along with resurfacing the rotors) if necessary air filter inspect your axle boots replace fuel tank cap gasket adjust valve clearances inspect the exhaust for leaks inspect your steering and suspension systems maybe pull you throttle body and EGR off and clean any carbon build out of them plus all the other stuff you said. Very nice write-up. Sounds like you are a tech who done his fair share of PMI's. If not, sounds like you'd make a great entry level tech. wow, thanks! I'm not a tech though. in fact, I'm only 17 and this is my first car. but I'm taking classes and hope to have an AS degree in automotive technology in two years and then be a mechanic after that. so that means a lot to me. ![]() Sounds like you could def handle getting into a dealership as an express tech (oil changes, tire rotates, PMIs, belts, ect). I recommend getting into the auto feild asap to build your expirence. Good luck -------------------- NASA/SCCA RX-7....currently under the knife
QUOTE(SlowCelica94 @ Jul 12, 2007 - 8:39 AM) [snapback]577768[/snapback] QUOTE(6strngs @ Jul 12, 2007 - 8:10 AM) [snapback]577705[/snapback] QUOTE(SlowCelica94 @ Jul 11, 2007 - 11:01 PM) [snapback]577672[/snapback] QUOTE(6strngs @ Jun 17, 2007 - 6:21 AM) [snapback]569221[/snapback] inspect all the hoses and replace ones that need replacing check the battery terminals for corrosion and clean if necessary inspect and the rotate or replace the tires if needed ispect your brake pads and replace (along with resurfacing the rotors) if necessary air filter inspect your axle boots replace fuel tank cap gasket adjust valve clearances inspect the exhaust for leaks inspect your steering and suspension systems maybe pull you throttle body and EGR off and clean any carbon build out of them plus all the other stuff you said. Very nice write-up. Sounds like you are a tech who done his fair share of PMI's. If not, sounds like you'd make a great entry level tech. wow, thanks! I'm not a tech though. in fact, I'm only 17 and this is my first car. but I'm taking classes and hope to have an AS degree in automotive technology in two years and then be a mechanic after that. so that means a lot to me. ![]() Sounds like you could def handle getting into a dealership as an express tech (oil changes, tire rotates, PMIs, belts, ect). I recommend getting into the auto feild asap to build your expirence. Good luck would if I could. 99.9% of all places like tire shops, oil change places, etc. all require that you have to be 18+ years old to work there. I just found out last night that America's Tire Co will hire a 17-year-old though so I'm planning on getting an application -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 11, '07 From Corona, CA Currently Offline Reputation: 4 (100%) ![]() |
there are lil cleaner tools availible at local car shops..it allows to shave down the post a little bit so that it becomes a lot cleaner and allows for better connectivity..check around cuz its pretty cheap for those..
or, if u have a file, u can file it around a lil bit. if its jus a lil bit of cleanin u need, u can jus pour a lil coca cola on the posts n wipe off the rest with a lil water n a towel ![]() -------------------- ![]() Pandelica 2.0 in progress. |
QUOTE(xs94st @ Aug 19, 2007 - 6:19 PM) [snapback]589218[/snapback] there are lil cleaner tools availible at local car shops..it allows to shave down the post a little bit so that it becomes a lot cleaner and allows for better connectivity..check around cuz its pretty cheap for those.. or, if u have a file, u can file it around a lil bit. if its jus a lil bit of cleanin u need, u can jus pour a lil coca cola on the posts n wipe off the rest with a lil water n a towel ![]() thanx...went to autozone and bought a spray cleaner for the battery...and wiped it down...came off pretty easy... |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) ![]() |
jsut use some coke, and a wire brush. worked perfect for me
didn't know if it would mess up my battery...never cleaned it before...i would have replaced it but batteries are so expensive...why change it if it works
Lo-Fi Version | Time is now: February 20th, 2025 - 12:00 PM |
