5sfe cams, does it fit?? |
Jun 14, 2007 - 2:07 AM |
Enthusiast Joined Nov 13, '06 From AUSTRALIA(MELB) Currently Offline Reputation: 0 (0%) |
hey guys i was looking for a set of cams for my 5sfe n i found tis information...
Crower Rods Have this part? Tell us about it! Manufacturer: Crower Part: Rods Description: Crower makes rods for both the 5S-FE and 3S-GTE engines. These are recomended if you are going to be adding serious horsepower to these engines. These rods have been made to hold their own on engines pumping more than 700 horsepower. The part numbers for the 5S-FE are B93754B(Brushed) or B 93754PF(Pressed Fit). The part numbers for the 5S-FE are B93753B(Brushed) or B93753PF(Pressed Fit). is it true???? so can i buy any 3sgte aftermarket cams and fit it to my 5sfe??? |
Jun 14, 2007 - 5:26 AM |
QUOTE(xxFROZENxx @ Jun 14, 2007 - 3:07 AM) [snapback]568353[/snapback] hey guys i was looking for a set of cams for my 5sfe n i found tis information... Crower Rods Have this part? Tell us about it! Manufacturer: Crower Part: Rods Description: Crower makes rods for both the 5S-FE and 3S-GTE engines. These are recomended if you are going to be adding serious horsepower to these engines. These rods have been made to hold their own on engines pumping more than 700 horsepower. The part numbers for the 5S-FE are B93754B(Brushed) or B 93754PF(Pressed Fit). The part numbers for the 5S-FE are B93753B(Brushed) or B93753PF(Pressed Fit). is it true???? so can i buy any 3sgte aftermarket cams and fit it to my 5sfe??? read the info, they make RODS, not cams. as in connecting rods. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Jun 15, 2007 - 12:32 AM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
served
Lo-Fi Version | Time is now: November 29th, 2024 - 12:34 PM |
