> oem side skirts interchangable?
post Jun 14, 2007 - 5:07 PM
Starcraftjunkie
Joined Nov 21, '05
From Wpg, MB. Canada
I did a quick search, and for the most part, no one knows for sure. Just lots of speculation and opinions.
Maybe we can put this to rest (or if it's been done, just point me to it. smile.gif
Are the oem skirts interchangable? Does the verts fit the hatches/coupe and vice versa?
Is it the same part #?
post Jun 14, 2007 - 5:12 PM
yes.
post Jun 14, 2007 - 8:41 PM
Starcraftjunkie
Joined Nov 21, '05
thx for the 'yes', but is there backup proof?
post Jun 15, 2007 - 12:03 AM
hitcachi
Joined Jun 19, '05
From Nebraska
yes.
post Jun 15, 2007 - 1:13 AM
goferris
Joined Feb 14, '07
From Provo, UT USA
the only body parts that aren't interchangable are the rear bumper and spoilers. so my answer is also yes
the rear is a little longer on the coupes and verts than the hatch. that and the lights.
post Jun 15, 2007 - 11:17 PM
QUOTE(Starcraftjunkie @ Jun 14, 2007 - 9:41 PM) [snapback]568636[/snapback]
LOL take my word for it?
I've had 3 sets of sideskirts. 2 of which came off hatches.
This post has been edited by Supersprynt: Jun 15, 2007 - 11:18 PM
post Jun 16, 2007 - 12:14 AM
Starcraftjunkie
Joined Nov 21, '05
now why would you go through 3 set of skirts?
This post has been edited by Starcraftjunkie: Jun 16, 2007 - 12:14 AM
post Jun 16, 2007 - 12:23 AM
Shocker
Joined Mar 23, '06
From Nashville Tennessee
so those stock skirt things on the verts will fit on a hatch?
post Jun 16, 2007 - 2:17 AM
azian_advanced
Joined Apr 18, '05
From Calgary
^ i don't see why not....
post Jun 16, 2007 - 2:41 AM
Shocker
Joined Mar 23, '06
i wonder what lip or rear extensions would go well with those skirts.
This post has been edited by Shocker: Jun 16, 2007 - 2:51 AM
post Jun 19, 2007 - 7:27 AM
laff09
Joined Jul 28, '06
From Delaware
anyone have the part # for stock skirts? Thanks
nm, found it. 76911-20900 (RH) and 76912-20900 (LH)
This post has been edited by laff09: Jun 19, 2007 - 7:29 AM
post Jun 19, 2007 - 4:18 PM
Velliety
Joined Jul 10, '06
From South Carolina
I can confirm that the oem hatch/coupe sideskirts do not fit the 'vert without some modification. I bought a set of OEM hatch/coupe skirts from madmods last year for my 'vert, and in order for them to fit the 'vert, you have to remove some of the bracing on the back of the skirts. Doesn't look like it's too hard to do (mine came already done since they were on madmods' vert already). They also don't snap into the holes that are there for the stock black 'vert sideskirts - I had to screw/rivet them to the car and then cover up the screws/rivets.
The sets of skirts are both the same length (the 'vert ones come in two pieces per side, and the hatch/coupe ones come in one piece) but I haven't tried to mount the 'vert skirts on the hatch so I can't say for certain that they will fit. The good news is that the 'vert skirts are small enough to ship regular UPS, they're not oversize so shipping isn't too bad if any gets a set just to play with. I sent my 'vert oems across the country to madmods for $12 shipping with UPS.
Samantha
post Dec 9, 2008 - 8:47 PM
do you have any pics of what to modify, or anybody for this matter
post Dec 9, 2008 - 9:57 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i'm pretty sure you just need to drill new holes since they don't mount up using the same vert holes. otherwise the length is the same (for all 6th gen models).
the process should be no more difficult than installing on a 94-95. that's just what i've read online, i never actually tried it in person.
post Dec 9, 2008 - 11:15 PM
trdproven
Joined Aug 2, '05
From Guam
It will fit, people here have the skirts on all models.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 10, 2008 - 7:12 AM
Velliety
Joined Jul 10, '06
From South Carolina
You have to cut some of the bracing out of the underside of the skirt, the entire length, since the vert is super-reinforced along its lower edge where the skirts go. Also, the holes will not line up at all, so you do need to drill new holes. I went with just three, one in each wheelwell, and one in the middle right under the door. A little plastic putty, sanding and painting, and you can't see the screws.
The stock regular side skirts will not fit the vert without that backside channel modification.
Samantha
post Dec 10, 2008 - 9:44 AM
trdproven
Joined Aug 2, '05
From Guam
Just make clean tapped screws thats it. The front will fit with the OEM bolt, tap the bottom and tap the rear. doublesided tape along the side.
This post has been edited by trdproven: Dec 10, 2008 - 9:44 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 10, 2008 - 2:35 PM
ill give it a try this weekned.
Lo-Fi Version Time is now: November 26th, 2024 - 4:47 AM
