> jdm camry's 5sfe, is it possible?
post Jun 16, 2007 - 11:02 PM
vile_v
Joined Jun 16, '07
From Vancouver, Canada
Hello fellow celica owners and/or toyota enthusiats
I've been reading pretty much most of the sticky and interesting posts on this forum and i like to stay the information here is awesome makes me really appreciate my celica more and more.
My 1st question/post is it possible to put an (97-02) jdm camry 5sfe engine into 95 celica GT (stock)? all i do know is that you have to do some drilling in the mounting plate for it to fit. but im not 100% sure.
post Jun 17, 2007 - 12:24 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Why? a "JDM" 5SFE isn't any better than a US 5SFE... Also... they mount the same.
This post has been edited by Kwanza26: Jun 17, 2007 - 12:25 AM
post Jun 17, 2007 - 12:56 AM
vile_v
Joined Jun 16, '07
QUOTE(Kwanza26 @ Jun 17, 2007 - 5:24 AM) [snapback]569211[/snapback]
well it doesn't matter where the engine comes from. its just that i can fine jdm engines for cheaper and with a lower mileage than some us 5sfe.
thanks for the info mate
post Jun 17, 2007 - 1:06 AM
My2Celi
Joined Dec 9, '05
From Bedford, TX
I got one, only cause my original 5s had over 200k on it and the only way that i could get another low mileage and cheap one would be from japan.
This post has been edited by My2Celi: Jun 17, 2007 - 1:07 AM
IPB Image <--- I miss :'' (
post Jun 17, 2007 - 1:23 AM
6strngs
Joined May 12, '06
From Wilmington, NC
Is the only difference between a JDM and USDM motor the EGR? so, if I wanted a newer replacement engine just cause mine's getting old, if I just re-use my current intake manifold so I can use the EGR, is everything else the same? would it be street legal then?
post Jun 18, 2007 - 5:54 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(6strngs @ Jun 17, 2007 - 6:23 AM) [snapback]569223[/snapback]
Yes. It's still the same basic motor... unless they radically changed ports or something (which I don't think they did). The major difference between the 97-2002 motors is DLI... but the physical engine has not changed very much.
post Jun 18, 2007 - 6:08 PM
Valo666
Joined May 15, '05
From Toronto
i got a 5s out of a jdm 95 Scepter. I reused my oem USDM intake manifold. The only difference between the JDM engine and USDM engine was that the ports on the JDM engine are slightly larger, and i think the compression ratio is just slightly higher..like 0.2 or 0.3:1 difference compaired to stock. I also noticed that just throttel response on the car is a bit different than other GT's and GTS' ive driven. Thats probably just because of the ports though. But yea, i bought my motor for $500 from a buddy of mine who used to import motors. it was a direct drop in because we used all of my oem acessories, sensors, intake manifold, etc.
post Jun 18, 2007 - 10:13 PM
cyb593
Joined Feb 22, '04
From USA
difference between the 2 also is a distributor and coils. that is one of the only different. we have both a 99 and 2000 camry and a 95 gt. that is probably most of the difference between them. now spec wise i dont know. g/l
post Jun 20, 2007 - 11:23 AM
Rockford
Joined Dec 22, '06
From Caracas-Venezuela
i think the 5S-FE is the toyota UDSM engine...
Celica ST202
post Jun 20, 2007 - 4:09 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Rockford @ Jun 20, 2007 - 4:23 PM) [snapback]570437[/snapback]
They're all basically the same thing, JDM or otherwise.
post Jun 20, 2007 - 5:11 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
All the 5sfe are all the same, except for the 94 and 95 have bigger shims. The mr2oc guys claim that it has 7-10 more hp.
post Jun 20, 2007 - 5:24 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(My2Celi @ Jun 20, 2007 - 10:11 PM) [snapback]570595[/snapback]
hahaha... because of the shims? The horsepower difference is due to emissions. The shim change was from roughly 1993 ish and the change covered all models till the 5SFE stopped production in late 2001. The change also affected the 3SGE's of the same era... Regardless... the 5SFE will still be a 130-135hp engine. The more I hear people preach about crap from mr2oc... the more I lose respect for those guys.
Lo-Fi Version Time is now: December 3rd, 2024 - 11:10 PM
