Gas Leaking |
Gas Leaking |
Jun 17, 2007 - 1:35 PM |
Enthusiast Joined Dec 21, '05 From Ontario Currently Offline Reputation: 1 (100%) |
Huge problem .. there is gas leaking from a pipe near the rear driverside wheel. (I apologize for not being descriptive enough). The pipe is quite rusted as I touch it and pieces of rust broke away.
I was just wondering if anyone has had this problem / knows how I can fix it? Also is it safe to drive (I'm assuming not since there's gas leaking) |
Jun 17, 2007 - 1:47 PM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
I wouldn't drive it if it's leaking gas. If you could take a picture I'm sure it would be more clear. You'll probably need to replace the fuel line.
-------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jun 17, 2007 - 2:03 PM |
I'm goin out to take a picture rite now, I couldnt find my camera.
Jun 17, 2007 - 2:20 PM |
Its the pipe that's all wet.
Jun 17, 2007 - 9:16 PM |
1. time to get off the snow tires
2. empty the fuel tank before anything bad happens 3. trace that metal line back to clean metal and splice in new line, bend it into place, put a bubble flare on the end of it, and reattach the rubber line. i'm not sure, but that looks like the fuel return line. -------------------- |
Jun 17, 2007 - 9:46 PM |
QUOTE(Bitter @ Jun 17, 2007 - 10:16 PM) [snapback]569412[/snapback] 3. trace that metal line back to clean metal and splice in new line, bend it into place, put a bubble flare on the end of it, and reattach the rubber line. I'm really a newbie when it comes to fixing my car myself. Would you be able to dumb that down a bit for me, you think it would be a hard job -- or should I just take it to a mechanic? |
Jun 17, 2007 - 10:36 PM |
Enthusiast Joined Nov 10, '06 From Cleveland Currently Offline Reputation: 0 (0%) |
There was recently another post with the exact same problem on this forum. There was a lot of discussion, pictures, etc. so I would try searching for it. Also, replacing fuel lines can be a real pain, especially if you have never done it before. If you don't have a lot of time to spend working on it, or if you can't get by without the car for a couple of days, I would just take it in.
Jun 17, 2007 - 10:54 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
If you don't do much work on your car I recommend asking a friend who knows what he's doing or take it in to a shop, playing with fuel lines is not fun a little spark and KABOOM !!! Their goes your car.....
-------------------- "To Protect And To Serve The Wealthy" -POLICE
Jun 18, 2007 - 10:17 AM |
Thanks for the advice guys! I called a shop and they said the part is going to cost over $200 so I'm gonna see if there's anyone on the forum that gets discounts at toyota.
Jun 21, 2007 - 11:13 AM |
Enthusiast Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
related thread:
http://www.6gc.net/forums/index.php?showtopic=46757&hl= what I ended up doing was using a tube cutter and a wire cutter i cut the rusted part out (the leaking part and as much of the rest) and threw some iirc 5/16 rubber fuel injector 50psi hose on. 2 work clamps and that was it. you should be ok to drive, only your mpg will go down the ****ter and your car will reek of gas. That it how I figured out i had a leak myself... |
Lo-Fi Version | Time is now: November 29th, 2024 - 3:52 PM |
