> A lot of squeeking coming from rear?
post Jun 17, 2007 - 2:03 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
I'm not very good mechanically, so I think it's a wheel bearing or brakes. It only happens when i'm rolling though. It's decently loud too.
- Ryan
aim: rkgreen04
post Jun 17, 2007 - 4:51 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
QUOTE(Akimbo @ Jun 17, 2007 - 12:03 PM) [snapback]569307[/snapback]
bearing is very possible
post Jun 17, 2007 - 9:01 PM
azian_advanced
Joined Apr 18, '05
From Calgary
my rear end used to squeak and it turned out to be the shocks.
post Jun 17, 2007 - 10:07 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
better not be, those are brand new. im thinking pads now.
- Ryan
aim: rkgreen04
post Jun 17, 2007 - 10:59 PM
Remy
Joined Jan 25, '06
From MN
"To Protect And To Serve The Wealthy" -POLICE
post Jun 17, 2007 - 11:03 PM
Valo666
Joined May 15, '05
From Toronto
is it when your driving you hear it all the time? or is it you only hear it when you hit the brakes? or when you hit a bump or when?? I have a squeak coming from my rear end too, but mine only happens when i hit a bump and its because i got a bad strut rod bushing.
post Jun 17, 2007 - 11:07 PM
kcizzle
Joined Jul 12, '06
Try this link:
http://www.6gc.net/forums/index.php?showtopic=45402
post Jun 19, 2007 - 7:28 AM
root
Joined Feb 26, '06
From Bowling Green, OH
I have had this problem too. Every now and then, at low speeds, I hear this squeaking when I leave on the gas and coast. I suspect the wheel bearing as well, but time will tell when I do coils and struts. I'll check it sometime if you'd like. I don't claim to know all, but I know enough to diagnose right more often than not.
post Jun 19, 2007 - 10:47 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Ive got a squealing type of noise that seems to amplify when I am on the gas, and less while coasting. Its like it gets louder as the RPM's increase, but it doesn't make much noise while going over bumps. I suspect its a wheel bearing frown.gif more money that isn't going to mods.
This post has been edited by 95CelicaST: Jun 19, 2007 - 10:48 AM
**** Photobucket
post Jun 19, 2007 - 12:12 PM
LewFX
Joined Jan 28, '05
I for once dont believe thats the bearing, perhaps an axle
post Jun 19, 2007 - 12:26 PM
95CelicaST
Joined Feb 5, '05
QUOTE(LewFX @ Jun 19, 2007 - 10:12 AM) [snapback]570033[/snapback]
**** Photobucket
post Jun 19, 2007 - 1:42 PM
LewFX
Joined Jan 28, '05
ahhh, that would help, if you need a rear bearing without abs, let me know i have one
post Jun 19, 2007 - 2:33 PM
95CelicaST
Joined Feb 5, '05
QUOTE(LewFX @ Jun 19, 2007 - 11:42 AM) [snapback]570054[/snapback]
depending. I'm going to have my mech. look at it and if he says its the wheel bearing then I will come knocking. smile.gif
**** Photobucket
post Jun 19, 2007 - 3:33 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
other from what u guys said...wanna check teh dust shields to see if its bumping on the rotor....
post Jun 20, 2007 - 6:26 PM
dennischan0919
Joined May 20, '07
From Massachusetts
should also check the rear tierod and control arm bushings, spray some silicone onto the bushings (one at a time), and take it for a ride, if noise goes away, bingo!
Lo-Fi Version Time is now: November 25th, 2024 - 8:55 PM
