3 Pages V  < 1 2 3 >
> How To Replace Wheel Bearing (Front)
post Dec 28, 2009 - 1:18 PM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
JDM ST205
post Dec 30, 2009 - 8:34 AM
trdproven
Joined Aug 2, '05
From Guam
some pics are not working.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 1, 2010 - 4:15 PM
Remy
Joined Jan 25, '06
From MN
I have this thread saved with pics on my hard drive do you guys still need it ??
"To Protect And To Serve The Wealthy" -POLICE
post Jan 1, 2010 - 4:51 PM
CelicaST_CALI
Joined Feb 28, '07
BANNED. for life, you moron.
post Jan 1, 2010 - 5:45 PM
Remy
Joined Jan 25, '06
From MN
Its a compressed file so u just need something to unzip it, its been tested and works and is virus free. wink.gif
Check couple post down for new link
This post has been edited by Remy: Jan 13, 2010 - 8:18 PM
post Jan 13, 2010 - 12:00 AM
Penkka
Joined Dec 20, '07
From Valkeakoski, Finland
does anyone has an old or new bearing, I need the measures of it!
My local dealer quoted the bearing alone at 300$, an I have the measures for a bearing that could be the right one from a part dealer, but he wasnt sure about the bearing. and he quoted it at 80$, so its very tempting..
320hp @ 6300rpm and 420Nm @ 3250rpm. yay!
My ST205 WRC buildthread
post Jan 13, 2010 - 12:07 AM
CelicaST_CALI
Joined Feb 28, '07
remy that file doesnt work for me?
File not found. It has been either deleted, or it never existed at all.
post Jan 13, 2010 - 9:32 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (Penkka @ Jan 13, 2010 - 12:00 AM) *
that sounds like the whole bearing, hub assembly. go to advanced or pepboys. i got mine for $50 bucks with a friends discount... it was supposed to be $90!
post Jan 13, 2010 - 9:49 AM
Penkka
Joined Dec 20, '07
no it doesnt include the hub, only the bearing and the two seals.
post Jan 13, 2010 - 9:53 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (Penkka @ Jan 13, 2010 - 9:49 AM) *
wow dude. i bought the bearing two seals. tie rod, lower ball joint. cv boot (and grease), and cotter pins for just over $150. like i said go to a parts place, not a dealership!
post Jan 13, 2010 - 8:17 PM
Remy
Joined Jan 25, '06
From MN
QUOTE (CelicaST_CALI @ Jan 12, 2010 - 11:07 PM) *
How to WB Replacement
post Jan 13, 2010 - 11:00 PM
Penkka
Joined Dec 20, '07
QUOTE (garin @ Jan 13, 2010 - 10:53 AM) *
parts place couldnīt say for sure would theyre item fit the GT4. thats exactly Iīd like to hear the measures!
post Feb 12, 2011 - 6:38 PM
97lestyousay
Joined Jul 7, '03
Make sure and double check all of your part numbers, I bought new hub bearing and seals from my local toyota dealership.
He didn't ask if it was ABS or not and ordered me the ABS version of the seal and dustcover, apparently the guy pressed in
the new bearing and hub didn't see the new dustcover is a 1/4 in taller, and it binds up when you tighten the axle nut.
The PN for the ABS version seal kit is 04422-20080 and it will not work on a non ABS celica.
This post has been edited by 97lestyousay: Feb 12, 2011 - 6:40 PM
JDM guy made me do it.
post Feb 13, 2011 - 12:24 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (97lestyousay @ Feb 12, 2011 - 1:38 PM) *
you sure?? i have an abs kit on my left side and non-abs kit on my right. both work perfect, the abs kitted side has a cut out on the retaining ring for the supposed abs sensor.
post Feb 13, 2011 - 12:53 PM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
I have an ABS on my passenger side and didn't seem to have any problems.
post Feb 13, 2011 - 1:54 PM
97lestyousay
Joined Jul 7, '03
Unless the guy distorted it when he pressed it in, my dust cover doesn't clear the outer axle, when I tighten the axle it binds when I removed the dustcover and tighten it, it spins free. The abs version is twice as tall as the non.
Edit: You do not have an ABS dust cover without an ABS axle. The non ABS has a notch, the ABS version has a small slot and is twice as tall.
The non ABS axle has 2 rings one that goes inside the dust cover, and one that sits just outside the dust cover closer to the tranny, it acts like a cap and is a larger diameter than the other, if you have an ABS dust cover it won't clear the larger ring on a non ABS axle, it sticks out too far and hits, I am going to need see pics.
This post has been edited by 97lestyousay: Feb 17, 2011 - 8:21 PM
post Jun 22, 2011 - 4:24 PM
mkernz22
Joined May 10, '10
From MA
To sort of bring this back from the dead, I need to replace my passenger side one as soon as I can. Is this the seal I would need for the WB? http://www.autozone.com/autozone/parts/199..._/N-j1pcaZ8oxmo
post Jun 22, 2011 - 6:38 PM
mak5603
Joined Oct 20, '08
Yeah bro. Timkens the way to go if it's not oem. Nothing less or it won't last.
Edit: and yeah that's the seal haha.
This post has been edited by mak5603: Jun 22, 2011 - 6:40 PM
2014 Toyota Rav4 XLE
post Jun 22, 2011 - 6:51 PM
mkernz22
Joined May 10, '10
From MA
I might order from the dealer. From the dealer the bearing is about $80, but I'll get that at autozone. The seals come together (inner and outer) so I'll order those from the dealer and they're about $30
post Jun 24, 2011 - 7:29 AM
Euphoria
Joined May 6, '08
QUOTE (97lestyousay @ Feb 13, 2011 - 1:54 PM) *
I don't understand what you mean, I have an abs hub and it works fine, the only difference I could see was there was a tab where the abs connects to it but without abs it leaves a little hole.
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: November 27th, 2024 - 5:03 AM
