Car Idles at 2200 |
Car Idles at 2200 |
Jul 28, 2003 - 8:43 PM |
Enthusiast Joined Jul 27, '03 From Maine Currently Offline Reputation: 0 (0%) |
car idles at 2200 drops down for a sec and goes back up......... any ideas on how to fix this?
Jul 28, 2003 - 8:47 PM |
Enthusiast Joined Jul 9, '03 From Tampa Florida Currently Offline Reputation: 0 (0%) |
try the t.p.s sensor
Jul 28, 2003 - 8:48 PM |
Enthusiast Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
1st, check throttle cable, could be getting ready to break and hanging up in housing, maybe just un-hook it from engine and see if prb still there. if not that, have codes read, probably some sensor (airflow, throttle position, oxygen, etc) lying to the computer.
Jul 28, 2003 - 9:16 PM |
its weird , it usualy idles at around 2,000 then drops down once in a while.......
does this change anyting>? |
Jul 28, 2003 - 10:19 PM |
Enthusiast Joined Oct 27, '02 From Barbados Currently Offline Reputation: 0 (0%) |
There are a number of things to check.
1) MAF 2) Oxyen sensor 3) vacuum hose |
Jul 28, 2003 - 10:45 PM |
Enthusiast Joined Nov 8, '02 From New Zealand Currently Offline Reputation: 0 (0%) |
Hi
Something basic to check first is have you got your AC (air conditioning) on? I know with my car when the ac kicks in the engine drops a few hundred revs, then after a while it returns to normal idle speed. If this was the first thing you checked or you already knew this, then please ignore this post -------------------- |
Jul 30, 2003 - 12:29 AM |
Enthusiast Joined Jul 29, '03 From Cyprus Currently Offline Reputation: 0 (0%) |
The problem might be with your idle valve, have it checked out or change it, i'm guessing that might be the problem.
Jul 30, 2003 - 1:19 AM |
Enthusiast Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
does it happen even when the engine is warm?
my car idles at around 2k rpm when i first start it in the morning then after 5 minutes it drops. -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Jul 30, 2003 - 1:37 AM |
Enthusiast Joined Mar 17, '03 From you like to know. Currently Offline Reputation: 0 (0%) |
umm my car idles at 700 when ac on 500 when ac off... not 2200!!!
Jul 30, 2003 - 9:10 AM |
Mine idles at 900rpm and with the a/c on 1000rpm. A friend of mine had a similiar problem with yours with his honda, we thought it was his idle valve. You should check out any possible parts related to your prob.
Jul 30, 2003 - 5:16 PM |
thanks guys
Jul 30, 2003 - 9:05 PM |
Enthusiast Joined Sep 30, '02 From NS Can Currently Offline Reputation: 0 (0%) |
Also wouldn't hurt to check your EGR valve!! And yeah to me 2,200 sounds a bit high!
Jul 30, 2003 - 10:42 PM |
its stoped now
Aug 5, 2003 - 11:01 AM |
Enthusiast Joined Jun 21, '03 From Pennsylvania Currently Offline Reputation: 3 (100%) |
so what was your problem......did you find it or it just went away on its own?
Aug 6, 2003 - 9:32 PM |
just went away put some chemicals in it.......... cleaned the injectors........... went away
Lo-Fi Version | Time is now: November 24th, 2024 - 8:38 AM |
