> afm to map conversion on a silver top, comments about converting silver top's afm to black top's map
post Jun 19, 2007 - 12:26 AM
ar2r02
Joined Jun 19, '07
From Philippines
you guys...i have a 4age silver top 20 valves on my corolla....and im wondering...i can change my AFM to a blacktop map sensor...they say it give a big boost.....but i read some forum threads here that it will produce bad idle, loss of power, etc...so any comments about this conversion??? any truth about this bad vibes???? really need your help..thanks!!!!
post Jun 19, 2007 - 12:35 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(ar2r02 @ Jun 19, 2007 - 5:26 AM) [snapback]569905[/snapback]
Mine had no problems. I think Coomer had some little issues not related to the actual conversion... and he did get them hammered out. I say... it's an excellent upgrade to do... and it's the BEST way to truely utilize ITBs.
This post has been edited by Kwanza26: Jun 19, 2007 - 12:38 AM
post Jun 19, 2007 - 2:06 AM
I don't have any real problems with mine either. I initially did, but it was just a vacuum issue.
post Jun 19, 2007 - 10:43 PM
ar2r02
Joined Jun 19, '07
From Philippines
will it be easier if i'll use stock Blacktop wiring loom for the conversion???
post Jun 20, 2007 - 4:12 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(ar2r02 @ Jun 20, 2007 - 3:43 AM) [snapback]570261[/snapback]
Depends on the car. Personally, I think re-pinning the ecu plugs would be easier.
Lo-Fi Version Time is now: December 3rd, 2024 - 6:30 AM
