> Dash MOD, Ideas on working in one...
post Jun 20, 2007 - 1:25 PM
ikey_karapat
Joined May 25, '07
From Dominica
I wanna stick in a switch DIN or something to that effect on my dash... I'm thinking 3 or 4 switches to control my trunk and cabin neons and couple other things... only thing is I have a double DIN stereo so that part's out... I was thinking maybe the part where the cigarette lighter is; just remove that and work in something with the switches on there..... ideas...??? kindasad.gif
If anybody else has done mods like that... a few pics could be good...
This post has been edited by ikey_karapat: Jun 20, 2007 - 1:27 PM
Ikey D.
Caribbean Style
post Jun 20, 2007 - 2:02 PM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE(ikey_karapat @ Jun 20, 2007 - 7:25 PM) [snapback]570500[/snapback]
The bit to the left (or right - depending on which country you are in) is replaceable. I am guessing you have the cubby hole. That can be replaced with an OEM three-switch panel that will take a range of Toyota switches or standard automotive rocker switches. Just need to find the right ones to use.
For trunk popper, how about the lexus trunk switch?
That is a Toyota part and will fit in the double-switch blank under your steering wheel (assuming you don't have 4-wheel steering).
post Jun 20, 2007 - 3:43 PM
ikey_karapat
Joined May 25, '07
From Dominica
I think this thing double posted on me... sorry.. moderators help a guy out yeah wink.gif
Ok mine is RHD so yeah it's the left.... I was just thinking, why don't I replace the cigarette lighter with an engine start button and put the switches next to it.....
Davey - where do I find that OEM switch panel you talking about? part number or name or sumtin....
Ikey D.
Caribbean Style
post Jun 20, 2007 - 4:04 PM
NaderG
Joined May 13, '07
From riverside, ca
I am not sure if this is possible , but what about the palce where the ashtray is ?
post Jun 20, 2007 - 5:15 PM
BloodyStupidDave...
Joined Nov 14, '06
QUOTE(ikey_karapat @ Jun 20, 2007 - 9:43 PM) [snapback]570561[/snapback]
These are for LHD but might assist:
Cover, Instrument Panel Hole (55548-20090) - this is the cubby hole
Base, Switch (from convertible) (55449-20100) - this is the panel to hold 3 switches
Sorry, can't find a picture of the Lexus trunk/gas switches panel.
This post has been edited by BloodyStupidDavey: Jun 20, 2007 - 5:53 PM
post Jun 20, 2007 - 5:24 PM
6gcSTVT
Joined May 3, '06
From New Hampshire
[quote name='BloodyStupidDavey' post='570596' date='Jun 20, 2007 - 5:15 PM']
[quote name='ikey_karapat' post='570561' date='Jun 20, 2007 - 9:43 PM']
[/quote]
So if you already have the cubby hole can "I" just buy the switches or is that cubby hole a "special one"??? also wouldn't those switches just rock back and forth and not stay up or down since they are "convertable top" switches?
This post has been edited by 6gcSTVT: Jun 20, 2007 - 5:29 PM
Darin H.
post Jun 20, 2007 - 5:36 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
how bout this
looks like he did a really good job on this. but instead of mounting a turbo timer just mount some switches there.
This post has been edited by goferris: Jun 20, 2007 - 7:26 PM
post Jun 20, 2007 - 5:53 PM
BloodyStupidDave...
Joined Nov 14, '06
QUOTE(6gcSTVT @ Jun 20, 2007 - 11:24 PM) [snapback]570601[/snapback]
I am guessing you already have the RHD version of the cubby hole. The switch panel replaces the cubby hole. Then you just pop the swithces or blanks into the panel. The switches themselves aren't part of the panel - they are seperate.
Toyota use basically the same switch size across most of their range. While you are right that the convertable switches aren't latching there are latching rockers and latching push switches that will fit into those holes (along with various other accessories). But as they nearly all have either screenprinted or 'glogo' lettering you may be better off using a generic rocker switch from your local auto spares shop. Choose carefully and you'll find one that is a good fit.
post Jun 21, 2007 - 8:10 AM
ikey_karapat
Joined May 25, '07
From Dominica
That lil panel looks like what I'm looking for... but where do I find it? and what do you guys think of putting an engine start button in the cig. lighter place... to match the switches???
Ikey D.
Caribbean Style
post Jun 21, 2007 - 10:01 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
i made a separate switch box, also put switched in the lil rectangles where your knees are
post Jul 12, 2007 - 7:13 PM
djseven
Joined Mar 25, '07
From Holland
I made this awhile ago...
post Jul 15, 2007 - 12:00 AM
forkee
Joined Nov 13, '02
From So Cal
post Jul 20, 2007 - 1:35 AM
Dragondog
Joined May 10, '07
From Lubbock, Texas
forkee i like ur speedo cluster where u get it
feedback
feedback
If I buy or sale please leave me feedback...thanks
cheap, quick, reliable, pick two
I treat my 6gc better then my own woman
post Jul 20, 2007 - 3:04 AM
forkee
Joined Nov 13, '02
From So Cal
QUOTE(Dragondog @ Jul 19, 2007 - 11:35 PM) [snapback]580448[/snapback]
ebay =)
post Jul 21, 2007 - 1:54 PM
6gcSTVT
Joined May 3, '06
From New Hampshire
As an update, that 3 switch panel for our cubby holes run around $8-10 at my toyota dealership. Has anyone bought the panel and fitted their own switches? If so which switches? Mine is coming in on monday/tuesday. I want to run my fog lights to one switch and my radar detector to another, what inline fuse size should I use for the radar detector?
Darin H.
post Jul 21, 2007 - 3:44 PM
Redline08
Joined Feb 23, '07
From Albany, NY
cut out the part with the cig lighter and cubby, then fill it with fiberglass.
Spread a thin layer of bondo on top of the fiberglass, then sand it down so it is flush with the rest of the piece, then you can drill the holes for switches and it will look clean, not like it was botched out of officemax plastic.
Lo-Fi Version Time is now: February 20th, 2025 - 2:56 AM
