> Whinning noise when I turn on my radio., I probably know the general answer.
post Jun 20, 2007 - 3:11 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
Ok guy/gals,
When I turn on my head unit (CD/radio/sirius/etc) I hear some feed back whinning noise coming through the speakers. And when I change CD tracks I can hear a garbled track-change noise through the speakers (it use to be I just heard this coming from the unit itself, never though the speakers). It has never made this noise before. The last thing I did was the premium 8 speaker set up (with stock amps) and it never made that noise before.
Now for the kicker (and I maybe waaay off base but...) I THINK this noise started when I recharged my a/c freon. I remember recharging it and when I turned on my car the a/c was COOL but I noticed that whinning noise. I may have put too much.... anyways. Am I retarded or something? If not, let me know.
Anyways I'm guessing its a grounding isssue..... sigh But where do I start? I mean dang its been awhile since I messed with my system. Im really dont want to go around and check every wire.
PS: Would having mutiple grounds be causing this?
post Jun 20, 2007 - 3:26 PM
Salt_City_GT
Joined Jun 14, '07
From Kearns UT
Does the whine echo the sound of your engine??
FAME < INFAMY
post Jun 21, 2007 - 9:48 AM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
QUOTE(Salt_City_GT @ Jun 20, 2007 - 3:26 PM) [snapback]570554[/snapback]
hmm thats a good question SCT..... hmmmm
I got to check if that is a symptom. If it does what does that mean?
This post has been edited by UTSlickVic: Jun 21, 2007 - 9:52 AM
post Jun 21, 2007 - 10:00 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(UTSlickVic @ Jun 20, 2007 - 3:11 PM) [snapback]570543[/snapback]
Ok guy/gals,
Thats Dr. Laura Schlessinger.
post Jun 21, 2007 - 10:05 AM
gt_driFFter
Joined Nov 29, '04
QUOTE(UTSlickVic @ Jun 21, 2007 - 10:48 AM) [snapback]570855[/snapback]
A bad ground somewhere
post Jun 21, 2007 - 2:23 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
run a ground wire from the mounting bracket on the side of the stereo to a good grounding point somewhere.
This post has been edited by bufferdan: Jun 21, 2007 - 2:24 PM
post Jun 21, 2007 - 2:59 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
QUOTE(bufferdan @ Jun 21, 2007 - 2:23 PM) [snapback]570941[/snapback]
Ok. But lets say I have mutiple grounds.... can that be a bad thing also? The reason I ask is because I thought I heard that having multiple grounds can cause feeback.
post Jun 21, 2007 - 3:33 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
idk...try it and see what happens. Ive had this issue before and just ran another ground off the radio and it has fixed it.
Salt_City_GT
Joined Jun 14, '07
From Kearns UT
I have never heard anything about multiple grounds but if so I would think that if any of them are bad you would get that sound. If the whine gets louder as you rev your engine then the ground is bad. You need to run a ground wire to a shorter ground than any of the others and if that fixes it then you just need to fix the bad ground. I had this same problem in my old car its a nuisance but easy to fix
FAME < INFAMY
post Jun 21, 2007 - 4:06 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
QUOTE(Salt_City_GT @ Jun 21, 2007 - 3:33 PM) [snapback]570969[/snapback]
Great! Thanks for the help guys. I will do it this weekend.
post Jun 21, 2007 - 9:31 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
supposedly... if you run power ground and signal next to each other instead of on diff sides of the car it can cause this, dont know if you re-routed any wires, or knocked a ground off somewhere n its just like hanging there not making contact, when you say multiple grounds... did you just split the normal black ground wire into 2 or three locations, or did you make diff grounds, per each amp and also the headunit itself?
Lo-Fi Version Time is now: February 23rd, 2025 - 4:41 AM
