> crazy 7afe
post Jun 20, 2007 - 7:03 PM
slow94st
Joined Oct 8, '06
From Jersey sHore PA
Ok so i was thinking, take my 7afe bottom end...........
lighten crank
2zz rods
4age head and pistons
lighten flywheel
port head
320° duration, with .400"/10.1mm lift camshafts
and some weber carbs
is that crazy enough
This post has been edited by slow94st: Jun 20, 2007 - 7:04 PM
3sgte next year i hope
post Jun 20, 2007 - 7:08 PM
and then what?
in a ~2800lb car, it'll still be slow.
now, put that into a ~1800lb stripped civic, and your talking some fun. wink.gif
post Jun 20, 2007 - 7:11 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
why carbs? EFI is soo much better!
post Jun 21, 2007 - 11:11 PM
pure_dx
Joined Dec 28, '05
From USA
QUOTE(presure2 @ Jun 20, 2007 - 7:08 PM) [snapback]570647[/snapback]
and then what?
rwd > fwd, stripped ae86 plz.
post Jun 22, 2007 - 1:03 AM
slow94st
Joined Oct 8, '06
ya i gess it can go in a ae86, btw carbs rule
post Jun 22, 2007 - 2:48 AM
Hanyo
Joined Aug 16, '03
From Bay area
so basically you made a carburated 2jzge (7th gen celica gts) without variable valve timing and lift?
ok....
post Jun 22, 2007 - 5:59 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE(Hanyo @ Jun 22, 2007 - 12:48 AM) [snapback]571208[/snapback]
ok....
2jz in a Celica? haha, i think you meant 2zzge, not 2jzge, this ain't no supra motor were working with here.
post Jun 22, 2007 - 11:31 AM
6gcSTVT
Joined May 3, '06
From New Hampshire
you guys have some crazy ideas......
But while your at it, why not take the 7afe and throw a vtec sticker on the valve cover laugh.gif
Darin H.
post Jun 22, 2007 - 8:09 PM
celica95st
Joined Jun 16, '05
From Baltimore,MD
I have my lower ended bored out to fit the pistons of the 2000 Celica GTS motor and runs a 12:1 compression....it makes so much of a difference. only modification i had to do to fit the head back on was to mill down the top of the pistons
post Jun 23, 2007 - 2:50 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
You can probably just swap in a 2ZZ and call it good. The amount of money needed to properly work the 2ZZ rods to fit the 7A will probably be pretty expensive. And those cams aren't gonna be very streetable... and you'll need a complete racing valvetrain to simply run those cams.
post Jun 24, 2007 - 12:59 AM
shubert_ae102
Joined Jun 23, '07
From central fl
QUOTE(6gcSTVT @ Jun 22, 2007 - 4:31 PM) [snapback]571267[/snapback]
hahahahaha
and every square inch of carbon fiber adds 2 hp. laugh.gif biggrin.gif rolleyes.gif
Lo-Fi Version Time is now: November 27th, 2024 - 8:31 AM
