![]() Enthusiast ![]() Joined Feb 20, '07 From Toronto, Canada Currently Offline Reputation: 0 (0%) ![]() |
hi folks,
Is there anyway 2 knw if i have a bad battery or a bad alternator? my car keeps dying overnight and runs beautifully once boosted. I turn it off for a few hours come back .. struggles to start and then stops responding completely. As soon as its boosted runs fine .. my instinct says its the battery. any ideas or experiences ? anythin will help thx -------------------- Looking for parts in the Ontario area .. if any1 can supply me some mods .. pm me .. THX
Looking for: Lowering Springs, Front Lip, JDM Rear Lights, Cold Air Intake |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '06 From massachusetts Currently Offline Reputation: 30 (97%) ![]() |
I am going to say that its your battery dude. If it were your alternator your car would start then die a little ways down the road. But since you say you charge it then run your car then after you shut it off it won't turn over that makes me lean towards the battery.
QUOTE(massbrandon @ Jun 21, 2007 - 10:18 AM) [snapback]570818[/snapback] I am going to say that its your battery dude. If it were your alternator your car would start then die a little ways down the road. But since you say you charge it then run your car then after you shut it off it won't turn over that makes me lean towards the battery. thx man .. i sent u a pm abt lowering springs ! -------------------- Looking for parts in the Ontario area .. if any1 can supply me some mods .. pm me .. THX
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) ![]() |
turn on the car.
once is running, disconect the battery, if it stays running the problem is your battery, if it dies you need a new alternator. I assume is your battery, by what you describe, but the test won't take you more than 5 minutes. -------------------- ![]() |
![]() Enthusiast ![]() ![]() Joined Dec 22, '06 From Caracas-Venezuela Currently Offline Reputation: 5 (100%) ![]() |
Battery... go for a new one!
-------------------- Celica ST202
Enthusiast ![]() Joined Oct 30, '05 From MICHIGAN Currently Offline Reputation: 11 (76%) ![]() |
QUOTE(atif7x7 @ Jun 20, 2007 - 7:58 PM) [snapback]570677[/snapback] hi folks, Is there anyway 2 knw if i have a bad battery or a bad alternator? my car keeps dying overnight and runs beautifully once boosted. I turn it off for a few hours come back .. struggles to start and then stops responding completely. As soon as its boosted runs fine .. my instinct says its the battery. any ideas or experiences ? anythin will help thx If you want your air bag light on go ahead and disconnect battery terminal while car is running . You may have bad cell in your battery or bad connection on the posts. Also check any possible draw from the battery. |
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From St. Paul, MN(USA) Currently Offline Reputation: 8 (100%) ![]() |
yeah disconnect the battery...disconnect the negative side and if stays running its your battery and if turns off its your alternator just like what Culpable04 said in the previous post..
Lo-Fi Version | Time is now: February 22nd, 2025 - 1:44 AM |
