i have a question, is it hard to wire 2 12" neon's together |
Jun 21, 2007 - 4:52 PM |
Enthusiast Joined Mar 26, '07 From CP 518 Currently Offline Reputation: 0 (0%) |
i went into a advanced autoparts today planning to buy 12" neons to put on both the driver side and passenger side right above where your feet go like shinning on my pedals and on the passenger side same spot. The product was optix 12" neon by streetglow and it game with a cigrette adapter and only one neon stick a pack and i need to know how to wire them together with out having all of the wires showing so its crisp and clean can anybody help
maybe i should of put this under the interior section my bad -------------------- |
Jun 21, 2007 - 5:00 PM |
Enthusiast Joined Mar 28, '04 From Ann Arbor MI Currently Offline Reputation: 9 (100%) |
route the wires behind the carpet /plastic also make an additional 12volt connection somewhere behind the center console thats mounted securely so you can plug it in there.
Jun 21, 2007 - 5:07 PM |
to route behind do you mean pull it through the center console like say i want everythign on the left side pull the wire through the to the left side of the center console like go behind it, im not that good with electrical work but with a little more info im sure i could do it
Jun 21, 2007 - 5:11 PM |
Route the wires behind the center console and splice them together. Run the ground to some bare metal down under the shifter and splice the power with the cigarette lighter. Then throw a switch in the line and mount it somewhere. done.
Jun 21, 2007 - 5:30 PM |
you make it sound so easy lol im 16 im sure if i saw someone do it i could do it because i can learn my watching my friend is pretty good with electronics so maybe ill call him i want it to be connected to a switch so hopefully i can get it done, this is off topic but is there any direct fit cat backs for 6gen ST, because greddy doesnt make the SP2 anymore for 6gens
Jun 21, 2007 - 8:06 PM |
Enthusiast Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
haha like he said, it is very easy, hardest part is physically mounting it on the passenger side so its not hanging in view and just produces a glow without being seen, if your going to do alot of interior mods, or light mods at least - like more neons, fog lights, neons under the car or in the grill, leds in the vents, id suggest making a switch box, i have one wedged between the drivers seat n the console, its screwed fast and sits at the front corner of the seat easy to reach, yet semi out of view
-------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Jun 22, 2007 - 11:32 AM |
alright thanks for the help and ideas ill try my best to get it done
Jul 12, 2007 - 7:04 PM |
Enthusiast Joined Mar 25, '07 From Holland Currently Offline Reputation: 0 (0%) |
like this?
Lo-Fi Version | Time is now: December 2nd, 2024 - 3:10 AM |
