![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) ![]() |
![]() ![]() ![]() if only i could get this knock sensor mod to work blah |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) ![]() |
QUOTE(urbandork @ Jun 21, 2007 - 4:26 PM) [snapback]571014[/snapback] ![]() ![]() ![]() if only i could get this knock sensor mod to work blah that looks so good. i think i am going to do something like that in my car. except instead of a turbo timer probably some switches. if i ever put a turbo in my car i am going to put the turbo timer where the clock is. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) ![]() |
looks good man...said it b4, and say it again, looks like it came stock. The LEDs are gonna look good when you get em wired up. For the knock sensor, you just gonna wire it up so when the signal comes through, it will light up the LED??...i remember seeing my friend wire up a similar thing for his TVIS on his AE.
QUOTE(Valo666 @ Jun 22, 2007 - 3:01 AM) [snapback]571118[/snapback] looks good man...said it b4, and say it again, looks like it came stock. The LEDs are gonna look good when you get em wired up. For the knock sensor, you just gonna wire it up so when the signal comes through, it will light up the LED??...i remember seeing my friend wire up a similar thing for his TVIS on his AE. still havnt figured out why my tvsv turbo pressure line isnt acting right so i made another plate that puts the EVC unit right in the middle. hopfully ill be able to get the LED mod to work correctly blah |
![]() Enthusiast ![]() ![]() Joined Mar 13, '07 From Gold Coast, QLD, Australia Currently Offline Reputation: 0 (0%) ![]() |
Absolutely fantastic! As Valo666 said, it looks totally stock!
Makes me with I had a turbo timer (or a turbo with which to use the timer!) ![]() |
QUOTE(Mangozac @ Jun 22, 2007 - 9:15 AM) [snapback]571215[/snapback] Absolutely fantastic! As Valo666 said, it looks totally stock! Makes me with I had a turbo timer (or a turbo with which to use the timer!) ![]() its actually a boost conroller.. but thats beside the point. Im just glad it looks stock as thats the look i was hoping for |
Lo-Fi Version | Time is now: February 23rd, 2025 - 11:34 AM |
