> Celica Headlights
post Jun 23, 2007 - 1:36 PM
dwebj
Joined Jun 23, '07
From Washinton
Hope this is a simple question to answer, I have a 94 St and need to replace a couple headlight housings, outer left and inner right. Im seeing them on Ebay alot but listed for St202-205's. Simple question is will those work?
post Jun 23, 2007 - 1:53 PM
Valo666
Joined May 15, '05
From Toronto
yea...the ST202-205 models are the same. They will be fine. ONly thing is, if you go with a ST205 projector headlight, you will need to cut the wiring for the low beams and install an H1 connector since it uses a different bulb
post Jun 23, 2007 - 2:03 PM
dwebj
Joined Jun 23, '07
From Washinton
QUOTE(Valo666 @ Jun 23, 2007 - 6:53 PM) [snapback]571588[/snapback]
Thanks Valo, going stock right now, have tons of the dreaded wife suck up before I get the projectors.
Lo-Fi Version Time is now: April 22nd, 2025 - 7:20 AM
