> removing sticker residue from oem skirts, tried all the stuff
post Jun 26, 2007 - 3:02 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
tried wd-40, pb blaster, goo-gone, thinner...EVERYTHING i can think of and these bastard things jus dont wanna get off me oem side skirts.... any tips?????
post Jun 26, 2007 - 7:23 AM
RbrtNdrws
Joined Jul 8, '04
From Durham, NC
QUOTE(DeW_H0e_GT @ Jun 26, 2007 - 8:02 AM) [snapback]572185[/snapback]
I used some bumper sticker remover that I bought from AutoZone I believe.
What I did was scrape away as much as I could first, then spray the area well and wait 3 -4 minutes to let it soak in. Then I scraped off a little more. It takes a while but if you keep repeating this eventually you can get it all off.
post Jun 26, 2007 - 2:18 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
goood deal ill try it later....
post Jun 26, 2007 - 2:25 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
goo gone works, you gotta rub it in with your fingers not a towel. chanh thought me this and it works really well
post Jun 26, 2007 - 2:30 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
fingers huh?..ill try it....
post Jun 28, 2007 - 2:58 PM
azian_advanced
Joined Apr 18, '05
From Calgary
haha.. that took me a while to remove to...
i used a torch and bumper sticker remover spray in tandem.. then after it became more pliable, i scraped and sanded it off.
post Jun 28, 2007 - 3:58 PM
LewFX
Joined Jan 28, '05
a towel just absorbs the goo gone and wont work, use fingers
post Jul 6, 2007 - 10:54 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
teh oem skirts have 2 clear film on the backside.....
the finger/goo gone trick works but only for the top portion....the bottom portion of the residue i jus use 60 grit sandpaper..and its REALLY messy.....
post Jul 6, 2007 - 11:00 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
try some epoxy or rubber cement. rubber cement worked for me, but don't leave it on too long otherwise it'll just make the situation worse... g.l.
post Jul 7, 2007 - 12:31 AM
RbrtNdrws
Joined Jul 8, '04
From Durham, NC
heat up the stuff maybe with a heat gun and its easier to rub off with your fingers.
post Jul 7, 2007 - 2:11 AM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(DeW_H0e_GT @ Jul 6, 2007 - 9:54 PM) [snapback]575771[/snapback]
huh... i just peeled mine off and they didn't have a sticky residue
gl with that.
post Jul 7, 2007 - 12:18 PM
RbrtNdrws
Joined Jul 8, '04
From Durham, NC
Lol. If you peel off the clear stickers in a certain way it will get most of the residue off. You have to peel it off steadily and dont stop because if you stop pulling for a second it will leave a line of residue where you stopped. I don't know if that makes sense but anyway...
post Jul 7, 2007 - 9:04 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Mac tools sells a rubber/plastic attachment for a drill chuck. Its a wheel that you can spin right on paint and will remove glue, stickers, adhesive, etc. Just be carefull not to spend too much time in one spot or spin it up too fast. Itll take the paint right off! Especially on plastic. I believe you can get this for $15-$20.
post Jul 9, 2007 - 2:44 PM
RbrtNdrws
Joined Jul 8, '04
From Durham, NC
Interesting, would an auto store have this you think?
post Jul 9, 2007 - 4:46 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(RbrtNdrws @ Jul 9, 2007 - 2:44 PM) [snapback]576509[/snapback]
probably not. Ill try to find it on mac or snap on website
Lo-Fi Version Time is now: November 23rd, 2024 - 6:01 PM
