How not to Drift |
How not to Drift |
Jul 1, 2007 - 4:01 PM |
Moderator Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) |
Jul 1, 2007 - 4:20 PM |
Enthusiast Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
That's a local RX7 here. It was not a drift event, but an autocross event at SGMP Racing. Apparently he was sold the wrong lug nuts, which didn't torque down properly causing all the lug nuts to fall off. Only damaged appeared to be to the front fenders, read quarter panels, and most likely the brakes.
Jul 1, 2007 - 6:36 PM |
Enthusiast Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) |
wow that **** sucks
Jul 1, 2007 - 8:47 PM |
Enthusiast Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
hahahah, if you loop the first 8 seconds over and over again its hilarious.
honestly, how can you put on the wrong lug nuts? if its the right thread it should go on perfectly. use a torque wrench to tighten it to spec and make sure it turns on there at least 8-10 rotations. its not rocket science... -------------------- |
Jul 2, 2007 - 6:47 AM |
QUOTE(forkee @ Jul 1, 2007 - 9:47 PM) [snapback]574174[/snapback] hahahah, if you loop the first 8 seconds over and over again its hilarious. honestly, how can you put on the wrong lug nuts? if its the right thread it should go on perfectly. use a torque wrench to tighten it to spec and make sure it turns on there at least 8-10 rotations. its not rocket science... There are some lugs that will fit, but not properly. Like 1/2" lug will thread onto a 12x1.5 stud but will not torque down. -------------------- |
Jul 2, 2007 - 1:21 PM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
That does suck.. another nice Jap ride being tortured by idiot owners
Lo-Fi Version | Time is now: November 29th, 2024 - 9:45 AM |
