![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
If you dont do a rear alignment, can it affect the steering wheel not being straight? i got a strange alignment issue and the steering wheel isnt straight.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) ![]() |
Yes
Despite sounding backward, the rear wheels determine what direction the car is pointed in. So, if they're not lined up with the chassis [called thrust angle], even if the front wheels are aligned right the wheel will be off when driving. -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
Yes even if the front wheels are aligned and the rear isn't, the rear could still point in a different direction than your front and cause it to steer wrong.
odd, grrr i guess ill hafta shell out some money for a rear alignment
![]() Enthusiast ![]() ![]() ![]() Joined Jun 8, '07 From Houston, Texas Currently Offline Reputation: 1 (100%) ![]() |
I got a 1-Year from NAPA so if they screwed somethin up I go back in and yell at em.
QUOTE(LewFX @ Jul 1, 2007 - 11:55 PM) [snapback]574222[/snapback] odd, grrr i guess ill hafta shell out some money for a rear alignment This is why you always get a 4 wheel instead of a front wheel alignment. Even on non adjustable rears the computer should see the thrust angle. I'm really surprised they even did a front wheel only. -------------------- ![]() |
can i adjust the rear toe, everything looks good but the driver side toe
its not that bad but i would like my steering wheel straight again...
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) ![]() |
Actually they were pretty persistent about Lew getting a 4 wheel alignment but we declined it because he didn't want to pay the extra 40 bucks... I guess they were right in the end.
Enthusiast ![]() Joined Jun 15, '06 From NJ Currently Offline Reputation: 1 (100%) ![]() |
the steering wheel should be centered even if they only did a front wheel alignment. when you do a front wheel alignement, the mechanic centers the steering wheel in the car and adjusts the front toe to match the rear toe, whether the rear toe is out of spec or not. the steering wheel should be centered. if your have them do the rear alignemnt, they will have to do the front over again.
i went to discount tire center and they said i need a camber kit. i guess i can order some crash bolts.
Lo-Fi Version | Time is now: February 18th, 2025 - 5:49 AM |
