> Engine smokes in the morning
post Jul 5, 2007 - 8:39 AM
dvcelica
Joined Dec 9, '06
From NY
Hi,
I have a problem with my Celica every time I turn on the car in the morning a white smoke comes out of the exhaust. The car runs fine but I'm worry that this can be a serious thing. Any idea was wrong? kindasad.gif
post Jul 5, 2007 - 8:47 AM
Jared95
Joined Apr 24, '07
From lufkin tx
QUOTE(dvcelica @ Jul 5, 2007 - 1:39 PM) [snapback]575153[/snapback]
Hi,
yeah man this is a problem with mostly all older high mileage cars. mine does it as well but it runs great.
post Jul 5, 2007 - 8:49 AM
dvcelica
Joined Dec 9, '06
From NY
QUOTE(Jared95 @ Jul 5, 2007 - 1:47 PM) [snapback]575155[/snapback]
Hi,
I guess you are right. My car has 178.000miles
post Jul 5, 2007 - 9:00 AM
atif7x7
Joined Feb 20, '07
From Toronto, Canada
Mine does it too but it runs excellent. Wish there was an easy way to get rid of the smoke. I think u have to change all the seals in the engine to get rid of it or somethin like tht
Looking for parts in the Ontario area .. if any1 can supply me some mods .. pm me .. THX
Looking for: Lowering Springs, Front Lip, JDM Rear Lights, Cold Air Intake
post Jul 5, 2007 - 9:06 AM
dvcelica
Joined Dec 9, '06
From NY
QUOTE(atif7x7 @ Jul 5, 2007 - 2:00 PM) [snapback]575162[/snapback]
We are talking about a lot of $$$$$$. I guess I'll get use to that biggrin.gif
post Jul 5, 2007 - 9:27 AM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
you could always switch to a "high milage" oil, they usually have more conditioners and are usually a little heavier so it helps with the seals etc..
also... when you start your car, let it idle for like 15-20 seconds at least if you can and arent in too much of a hurry, and when your done driving also let it idle for about the same 15-20 seconds
doing both should reduce the amount of oil you burn, its not going to stop it or reverse any wear on the engine, but it will help a bit
also, avoid high rev driving, such as drive up to like 5k in 2nd gear then let the engine hang while you coast to a stop... sounds cool but puts a good deal more strain on the engine parts that are causing you to burn oil
post Jul 5, 2007 - 3:56 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
Could always just be the exhaust burning off water condensation when started up first thing in the morning
post Jul 5, 2007 - 4:01 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
its just worn/cracked valve seals. you can replace them easily with the ToyoTool. whats happening is you valve seals are letting small amounts of oil to drop into the cylinder when the vehicle is off. when u start the engine the oil is then burnt and thats what you see. its fine, but does increase oil consumption.
post Jul 5, 2007 - 6:58 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
add a little ATF to the oil, about 1/4 quart. it'll help a little.
post Jul 5, 2007 - 9:48 PM
atif7x7
Joined Feb 20, '07
whats a Toyotool ? easy to use ?
post Jul 6, 2007 - 7:17 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
http://www.toyotool.com/
A valve tool that will replace the valve springs and valve stem seals with the head on
the engine or off. Easier to use than other Valve tool & Valve Spring Compressor
Specifically designed for 4 valve heads
I did my valve springs with it with the head still on, and it was a snap with toyotool.
post Jul 6, 2007 - 7:49 AM
dvcelica
Joined Dec 9, '06
From NY
post Jul 6, 2007 - 7:57 PM
joehernandez
Joined Aug 5, '06
From San Luis AZ
QUOTE(x_itchy_b_x @ Jul 5, 2007 - 4:01 PM) [snapback]575317[/snapback]
thats what i was going to said!,, mine does the same, but its nothig that will cause much trouble huh
post Jul 8, 2007 - 12:15 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
I thought white smoke meant burning coolant, isn't burnt oil smoke blue?
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Jul 13, 2007 - 11:39 AM
atif7x7
Joined Feb 20, '07
Bluish White i would say -> Oil Smoke
Lo-Fi Version Time is now: November 27th, 2024 - 2:41 AM
