> Thud, clank, bang, noise from bay.
post Jul 5, 2007 - 10:29 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
I just replaced the motor in my car. I took many things off the car. Now there is a noise coming from my motor/transmission like something is loose and banging. It only happens when I'm in gear. It goes away when I step on the throttle in the low gears. Cruising, it's very loud with constant low throttle.
I'm hoping it's just the transmission mount.
Any experiences? Suggestions?
O yea. I'm going straight when this happens. As I replaced an axle too.
post Jul 6, 2007 - 2:47 PM
laff09
Joined Jul 28, '06
From Delaware
QUOTE(purplegt4 @ Jul 5, 2007 - 10:29 PM) [snapback]575422[/snapback]
Sounds like a mount or possibly exhaust?
post Jul 7, 2007 - 12:54 PM
alltracman78
Joined Aug 9, '06
From Ma
It's unlikely it's a mount if it happens when you're cruising.
Check your axles.
The inner joints.
Hard to say without being there though.
post Jul 7, 2007 - 4:13 PM
purplegt4
Joined Feb 7, '03
ok hmm...let's see.
it only makes noise when I am giving it gas. I let off and it stops.
man...i'm starting to confuse myself.
post Jul 11, 2007 - 12:33 PM
purplegt4
Joined Feb 7, '03
wheel bearing.
post Jul 11, 2007 - 12:36 PM
it was your wheel bearing?
post Jul 11, 2007 - 1:12 PM
purplegt4
Joined Feb 7, '03
yea. never knew a wheel bearing could make that noise, as the other side was a completely different sound.
post Jul 11, 2007 - 1:20 PM
weird, well i guess it was a good thing it was the bearing they are cheapo to fix
post Jul 12, 2007 - 1:12 AM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
QUOTE(playr158 @ Jul 11, 2007 - 6:20 PM) [snapback]577386[/snapback]
When I did them on a late 80s Camry (mcpershon (sp) strut design) they were a pain to get out, simply due to the age to rust ratio and the midwest's fine weather and roads.
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
Lo-Fi Version Time is now: December 3rd, 2024 - 8:05 AM
