> Horn wiring
post Jul 7, 2007 - 9:36 PM
kerosene
Joined Jul 4, '07
From US
Well, i took my horn out and made sure it works on my 4runner, which it does, and the horn off the 4runner doesnt work on my car... I know that the fuses are good, which means it is the wiring....how do i check the wiring ....how do i remove the airbag to see if the metal is making contact... cheers to anyone who helps
post Jul 7, 2007 - 10:29 PM
first check the "horn" fuse under the hood.
post Jul 7, 2007 - 10:45 PM
kerosene
Joined Jul 4, '07
From US
QUOTE(Batman722 @ Jul 7, 2007 - 10:29 PM) [snapback]576033[/snapback]
well i checked the one under the hood and the one in the fuse panel, and both seem to be fine....ill check them again to be sure....they are a bit big though....is there an easy way to take them out?
post Jul 7, 2007 - 11:37 PM
the one under the hood is a normal 10amp fuse I believe, not a bigger fuse or relay.
here's a pic
post Jul 7, 2007 - 11:56 PM
kerosene
Joined Jul 4, '07
From US
I just checked it, the fuse is one lower than what you pointed to, and on the panel i have (cover for fuses) it says that the other one i pointed to is a HORN fuse also
post Jul 8, 2007 - 7:58 AM
kerosene
Joined Jul 4, '07
From US
I verified today its not the fuse, i took a new 7.5 fuse and replaced it...and still nothing.... I took the sides off where the screws are to take off the horn, and it looks like its making contact... what color are the cables, the previous owner of the car f***ed with a lot of things in the car, maybe he cut it...theres a black and white, yellow hanging down for sure...
weird wires and harness going into nothing and there is also a led there that i dont know what it goes into...
2 wires that are tapped into the bundle by the door
the blue/red cable, is the same cable connected to the horn (i think) and theres a gator clip tapped into it
Weird Led thats tapped into the main cables...
Edit: I added images....
This post has been edited by kerosene: Jul 8, 2007 - 8:20 AM
post Jul 8, 2007 - 10:48 AM
kerosene
Joined Jul 4, '07
From US
Batman722 told me that its a car alarm system, i couldnt find the horn cable, so i purchased a car alarm, and ill hook a new one up, hopeing it will work...
post Jul 8, 2007 - 11:42 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
the horn could be either a positive ground or a neg ground. hook a multimeter up to the end of the horn wire.
post Jul 8, 2007 - 11:51 AM
kerosene
Joined Jul 4, '07
From US
QUOTE(rjbibeau @ Jul 8, 2007 - 11:42 AM) [snapback]576124[/snapback]
I dont know where it is...batman said its green, but i have a few green wires...but nothing that i can guess though
post Jul 8, 2007 - 2:33 PM
kerosene
Joined Jul 4, '07
From US
ok, now im positive that its the wiring, at some point from the relay to the steering wheel there is a break in the connection...
Update: I found the problem, and im in the middle of fixing it... the cable that is under the pillow that does the actual touching to the metal was snapped off, have to figure out how im going to replace it now...
Update: I finally fixed my horn
This post has been edited by kerosene: Jul 8, 2007 - 4:18 PM
post Dec 21, 2010 - 1:25 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
QUOTE (kerosene @ Jul 8, 2007 - 12:56 AM) *
Hi guys, reserecting this thread: My horn is out, first time ever. Checked the 7.5A fuse and its fine but I need to check the relay. Where is this horn relay? Looking at this picture above, is it the top-most yellow arrow? I hope its that easy.
Next thing I will check is the connector behind the airbag. Then I will check the horn itself. After that, if none of those things helps fix it... I'm up a s#@t creek and asking yall for more help.
thanks
post Dec 22, 2010 - 2:22 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
------ bump- -----
Anyone?
post Dec 22, 2010 - 5:21 PM
Imawakeyo
Joined Apr 20, '10
From Virginia
Probably the cable that goes under the air bag. Mine wasn't working and I didn't notice it until I was taking my heater core out and had to remove the steering wheel. Mine was snapped off probs due to age. It's a simple fix. Hope that helps smile.gif
post Dec 22, 2010 - 11:58 PM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
QUOTE (Imawakeyo @ Dec 22, 2010 - 5:21 PM) *
Yeah I had read that^ in this thread and in others. It was on my list of things to check, which I did... and it was indeed that connector/wire that is behind the airbag. Once again the 6gc community provided me with information that would take hours if not days for someone to figure out on there own. Plus I did find the horn relay... duuurrr... underneath the engine bay relay/fuse-box cover has what each one goes to... the gray box is the horn relay (which btw had no idea how to check if its good or bad). Anywho checking three things, finding the problem, and fixing the problem took ~1 hour). I really appreciate this forum and its contributing members!
-Vic
post Dec 29, 2010 - 9:43 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Lo-Fi Version Time is now: February 23rd, 2025 - 2:12 AM
