"proper" introduction, I'm 17 with a 94 hatch |
Jul 8, 2007 - 1:14 AM |
My name is Stephen, pronounced like Steven, lol, I'm 17. I bought the car with 127xxx for 4k drive out, with the dealer dropping in a 60k motor in it. He wanted $4900, I talked him down with cash. Its the ST, it was relatively stock, with an upgraded deck and speakers. Black interior and exterior. Sun/Moon roof(difference?) new tires, and its a 5 speed. Though its an ST, still debating weather i should swap in a 3VZ FTE into this car, or buy a wrecked alltrac and work on that. Ideas/suggestions?
This post has been edited by stephen_lee: Jul 8, 2007 - 1:16 AM -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Jul 8, 2007 - 1:27 AM |
Enthusiast Joined Jan 30, '06 From Augusta, GA Currently Offline Reputation: 4 (100%) |
Nice car. Welcome.
What's the 3VZ FTE from? The 3VZ-FE is from the Land Cruiser, I believe. Would that even fit? -------------------- 2007 Subaru Impreza WRX STi 1974 Datsun 260Z 1997 Subaru Legacy L Wagon Kind of missin' my Celica GT! Hit me up if you're ever in my area. I'm always down for a meet. |
Jul 8, 2007 - 1:46 AM |
the 3VZ FTE is the 3VZ FE + turbo. it came with 92-93 Toyota Camry V6, and the Lexus ES 300. cool thing is the ECU has no governer, redline is 7200, wont throw a CEL if its evap, egr and all arent quite there for some reason, and its pretty beefy stock.
pretty crappy pic, there was a better one but idk where it was. the guy has no idea that the 3s is a 4? lol anyway the rods are named right lol This post has been edited by stephen_lee: Jul 8, 2007 - 1:48 AM -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Jul 8, 2007 - 2:02 AM |
Enthusiast Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
its a moonroof if u can see through it. like a glass window type deal that opens upwards and slides back. if its a solid body piece that acts similarly, then its a sunroof. the moonroofs usually include the little roof piece that you can slide back by hand. i would know as i have a moonroof i think they are cooler... haha
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
Jul 8, 2007 - 1:04 PM |
Enthusiast Joined Oct 9, '02 From Longmont, CO Currently Offline Reputation: 1 (100%) |
The 3vz-fe motor came in 88-95 4-runners, 88-95 toyota Pickups, and 93-95 T100's.
The 2vz-fe came in 88-91 Camry's and 88-91 es250's The v6 motor that came in the newer camry's and es's was the 1mz-fe |
Jul 8, 2007 - 11:36 PM |
From Wikipeidia
QUOTE The 3VZ-FE came to life when Toyota recognized that it needed a larger V6 engine to suit the then-upcoming 3rd generation Camry platform. Its basic design incorporates an updated version of the last revision of the 3VZ-E's block, mated with the Yamaha designed and built DOHC (24 valve) FE V6 heads, and Toyota's most advanced OBD-I control system. The upper aluminum intake manifold has is a split chamber intake manifold with Toyota's ACIS varriable intake system feeding three sets of runners for both heads. Parts-wise, the 3VZ-FE shares very little with previous engines, including the 3VZ-E, and 2VZ-FE. The few parts shared with the 3VZ-E that are interchangeable are the main bearings; little else is the same. In a surprising twist, no electronics from other Toyota (Denso) parts are swappable. It is a smooth running engine that was used as the 3.0 L V6 engine on the Camry platform between 1992 and 1997.5 depending on the market: North America saw the engine only in 1992 and 1993, while Australia and New Zealand had it from 1992 through 1996, and the engine was available in some parts of Asia, and in the JDM Toyota Windom through 1997.5. The 1992-1993 engine has 185 hp (138 kW) at 5800 rpm and 189 ft·lbf (256 N·m) at 4600 rpm. 1994+ have 200 hp (149 kW) at 5800 rpm and 204 ft·lbf (277 N·m) at 4600 rpm. There is no mechanical difference in the engine. In an embarrassing move, Toyota inadvertently created an engine competing with the more performance oriented 7M-GE and 1JZ-GE installed in sportier, more luxurious cars of the time. Because of this, both stock ignition timing, and fuel tuning were set more conservatively than normal capping power output. The power spread of the 3VZ-FE is wide, having 100% torque at just 2500 rpm - 4600 rpm, with power trailing off by 6000 rpm. Stock redline is 6850 rpm, and the ECU's fuel/ignition cut is over 7000 rpm. The valvetrain was designed for no float over the stock programmed operational range. Though harder to find in good used condition in North America (unless imported), the 3VZ-FE is a fairly common V6 in most parts of the world, after having a good lifespan in popular models. They are cheap, simple, have few problems, and have become a semi-popular subject for engine swaps. The 3VZ-FE also started Toyota's trend of severely overbuilding their production V6 engines. Having a larger forged steel crankshaft, and large cast rods, they are capable of more than doubling stock power output easily. With a few nitrous, and turbocharged examples matching, or exceeding 450 hp (336 kW) on both the stock engine, and stock engine management with a piggyback/interceptor controlling fuel/ignition.[code][/code] sorry, but i think this is right -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Jul 9, 2007 - 1:40 AM |
Enthusiast Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
QUOTE(phat94celi @ Jul 8, 2007 - 12:04 PM) [snapback]576146[/snapback] The 3vz-fe motor came in 88-95 4-runners, 88-95 toyota Pickups, and 93-95 T100's. The 2vz-fe came in 88-91 Camry's and 88-91 es250's The v6 motor that came in the newer camry's and es's was the 1mz-fe the 3vzFe only came in 92-93 camrys/es300. you are thinking of the 3vze, completely different engine -------------------- I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Jul 9, 2007 - 7:58 AM |
QUOTE(celicaST @ Jul 9, 2007 - 12:40 AM) [snapback]576382[/snapback] QUOTE(phat94celi @ Jul 8, 2007 - 12:04 PM) [snapback]576146[/snapback] The 3vz-fe motor came in 88-95 4-runners, 88-95 toyota Pickups, and 93-95 T100's. The 2vz-fe came in 88-91 Camry's and 88-91 es250's The v6 motor that came in the newer camry's and es's was the 1mz-fe the 3vzFe only came in 92-93 camrys/es300. you are thinking of the 3vze, completely different engine My info came straight from wikipedia. It may be wrong. EDIT: And aparently I looked at the wrong thing on the wiki page. My bad This post has been edited by phat94celi: Jul 9, 2007 - 8:00 AM |
Jul 9, 2007 - 10:19 AM |
Enthusiast Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) |
nice clean celica man... reminds me of a few years back when i was 17 and just got my celica... good times
Jul 9, 2007 - 5:26 PM |
Enthusiast Joined Sep 28, '03 From Bloomington, IN Currently Offline Reputation: 0 (0%) |
those 3vz rods don't look that much thicker then 3s-ge rods. I'd go 3sgte
-------------------- NASA/SCCA RX-7....currently under the knife
92 Civic hatch B16 - Sold 10th anniv RX-7 - RIP The Slow Celica - Sold...and then crushed crushed due to street racing. Quote from Seinfeild: George's Boss reading a magazine: "People magazine's most beautiful people. Oh and a Celica...nothin wrong with that!" |
Jul 9, 2007 - 10:30 PM |
Enthusiast Joined Jan 19, '07 From Indianapolis Currently Offline Reputation: 0 (0%) |
dont always trust wikipedia either, anyone can go in and edit the information in the system. I'd love to see a V6 Celica, I know someone on here has one completed, but thats only 1. i think ur car looks sweet, man, why buy a wrecked all-trac when u can turbo this celica and keep the amazing looks?
Jul 9, 2007 - 10:55 PM |
Enthusiast Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) |
wat kinda hp is the 3vzfte pushing at the wheel?and whats the rough price tag fully installed and running?
-------------------- BANNED. for life, you moron.
Jul 10, 2007 - 2:08 PM |
3VZ FTE will put out 350 WHP easy on like 13 lbs of boost plus 200 or so pounds of torque from 2000 rpm. the only reason i really want the V6 is the low end torque. This V6 also has a pretty high redline/fuel cut.. 6850/7200RPM, WIDE power band.. just gonna miss my 25 or so MPG
Also i was looking at a rolled '93 Camry a few weeks ago to get the engine. on the timing belt cover it says 3VZ and the emissions sticker 3VZ FE. I looks like it would fit nicely, new motor mounts, turbo over the tranny, some good heat shielding and we're set. -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Jul 10, 2007 - 6:02 PM |
wats the price and the mpg?
Jul 11, 2007 - 1:09 AM |
about 18 MPG
cost: 8k for everything 1/4 mi: 12.24 sec @ 119mph 0-60: 4.3 top speed: 147 CarTest says atleast lol idk if i should trust a program -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Jul 11, 2007 - 1:52 AM |
i dont think id pay 8k for that...
Jul 15, 2010 - 8:08 PM |
whooaaa my intro thread!
damn i miss my black celica! -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Jul 16, 2010 - 9:41 AM |
what happened to it,
Jul 16, 2010 - 9:52 AM |
durango into the PS quarter panel
Jul 16, 2010 - 10:42 AM |
Enthusiast Joined Nov 2, '09 From Tacoma, Wa. Currently Offline Reputation: 2 (100%) |
welcome pretty sweet car you got. i thought the 1mz-fe came in those year camrys and the 3vz-fe came in the late 80s to early 90s toyota pick up trucks.
This post has been edited by Lenny: Jul 16, 2010 - 10:46 AM -------------------- 1994 Celica GT- TenzoR 1.8in. Drop springs. 16mm wheel spacers.
Lo-Fi Version | Time is now: January 10th, 2025 - 6:04 AM |
