> 5s-fe engine problem, i have a problem with something in my engine
post Jul 8, 2007 - 4:34 PM
unionbay101
Joined May 15, '07
From El Paso, TX
so ok as im crusin around town i noticed that my engine light just turned on and for the last couple of days i have been noticing that the engine is sputtering around 3400-4000 rpm in second and third gear frown.gif ...so im thinking its the oil that needs to be changed but im not sure if its just that...because im loosing alot of horsepower i smash the gas and i can barly notice a difference in speed so if someone can help me out with this i have a gt 95 with a 5s-fe engine any help would be much appreciated thanks![b]
post Jul 8, 2007 - 7:08 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
find an obd-1 reader and see if u can find out wut Check Engine Light (C.E.L.) codes its throwing.. that'll narrow it down. sounds like some sort of leak though... hows it idle? pretty rough/smooth?
post Jul 8, 2007 - 10:20 PM
unionbay101
Joined May 15, '07
From El Paso, TX
QUOTE(cjh4l22 @ Jul 9, 2007 - 12:08 AM) [snapback]576257[/snapback]
rough...the rpms move alot
post Jul 12, 2007 - 4:15 PM
Kerr1
Joined Dec 24, '06
From jonesville
prolly need to clean ur Egr valve...i had the same problem a few weeks ago...cleaned it and runs fine...check tho hole in the manifold where the egr bolts in make sure its not clogged.
post Jul 12, 2007 - 4:43 PM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
QUOTE(Kerr1 @ Jul 12, 2007 - 9:15 PM) [snapback]577908[/snapback]
Agreed.
One of the most common CEL codes is a P0400 aka bad oxygen sensor.
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
post Jul 19, 2007 - 8:12 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
I had something similar happen to me today. I was driving home from work and then on came the check engine light out of the blue. My car was running fine before and was running fine after, but it was a rainy day and with my CAI I immediately thought I sucked up some water. I got in there and checked the filter and it seemed dry, if anything, a couple drops of water had hit it. I disconnected the filter and ran the engine at home and everything seemed normal, but the light was still on. Ideas? kindasad.gif (all fluid levels checked out and I have no leaks that I can see)
post Jul 20, 2007 - 12:26 AM
soven
Joined Mar 14, '05
From Auckland,New Zealand
When was your last oil change anyway?
post Jul 20, 2007 - 11:25 AM
Sinyk
Joined Oct 4, '06
QUOTE(soven @ Jul 20, 2007 - 12:26 AM) [snapback]580435[/snapback]
like 3000 kms ago, it's not due.
I drove to work today and I didn't notice anything different, it felt normal, so I assume whatever it is is minor, but I think I'll still take it in for a check tomorrow.
This post has been edited by Sinyk: Jul 20, 2007 - 11:32 AM
post Jul 21, 2007 - 12:42 AM
SlowCelica94
Joined Sep 28, '03
Just so you guys know, you can go to autozone (or was it Advanced?) and get your codes read for free. Take advantage of this, it'll save you a headache.
post Jul 23, 2007 - 12:39 PM
Sinyk
Joined Oct 4, '06
No autozone's up here in Canada
post Jul 23, 2007 - 1:52 PM
SlowCelica94
Joined Sep 28, '03
QUOTE(Sinyk @ Jul 23, 2007 - 5:39 PM) [snapback]581512[/snapback]
Bummer! Do you know how to count the blinks on your CEL?
post Jul 23, 2007 - 4:56 PM
alltracman78
Joined Aug 9, '06
From Ma
In your diagnostic port jump TE1 and E1 with a paper clip [make sure it will fit, if it won't slide in DON'T force it], turn your key to on.
Your CEL will blink.
Count the # of blinks. It will be a 2 digit #.
In regards to the original poster, I don't think Autocrap will read his codes [he's OBDI], and he's not going to have ANY P0 codes.
post Jul 24, 2007 - 4:22 PM
Sinyk
Joined Oct 4, '06
Actually, there's a shop a block from my work that can read it so I'm going over there after work and the guy is going to read it for free. If I have to have work done, I can just drop the Celi off and walk smile.gif I'm sure all will be well, but who really knows?
post Jul 25, 2007 - 6:05 AM
Dragondog
Joined May 10, '07
From Lubbock, Texas
what kind of engin do i have car is a 94 gt coupe 2.2l is it a 5 or a 7sfe or whatever...and what tranny 5spd all stock i think
This post has been edited by Dragondog: Jul 25, 2007 - 6:06 AM
feedback
feedback
If I buy or sale please leave me feedback...thanks
cheap, quick, reliable, pick two
I treat my 6gc better then my own woman
post Jul 25, 2007 - 7:11 AM
Gary
Joined Aug 28, '04
From FLA USA
QUOTE(Sinyk @ Jul 24, 2007 - 5:22 PM) [snapback]581955[/snapback]
That's because yours is OBD II.
The original poster's car is OBD I.
_Gary
post Jul 25, 2007 - 1:24 PM
Sinyk
Joined Oct 4, '06
Ok, and that allows me to drop my car off at once place and walk more than OBD I would? cwm13.gif
Regardless, I had it checked this morning and it's saying that there's insufficient EGR flow. Seems coincidental that the first problem on my old car was EGR as well. If the rad goes next, that will be scary.
This post has been edited by Sinyk: Jul 25, 2007 - 1:24 PM
Lo-Fi Version Time is now: November 27th, 2024 - 1:33 AM
