> how to program a keyless remote?
post Jul 9, 2007 - 7:33 PM
monky32
Joined Oct 19, '04
From orlando
Hi guys i have a 1998 celica. my keyless remote just broke so i went to the dealership to buy a new remote well i paid 47 bucks for and they were going to charge 50 dollars for programming my remote when i know it takes less than a minute to do so. A guy did it for my the first time i lost my remote but i don't know how to do it. could somebody share the programming sequence!!! thanks very much.
post Jul 9, 2007 - 7:50 PM
GreenyST204
Joined Apr 11, '06
From Tasmania
It Depends what remote you have
i got this one
and here is the howto
SDOC0265.pdf
Ok Gladys, lets play house, you be the door and I'll shut you.
post Jul 9, 2007 - 8:36 PM
monky32
Joined Oct 19, '04
From orlando
i actually have the three buttom banana look remote. i know my car has a buttom next to the steering wheel left hand side you have to press that buttom in a sequence to program the remote.
post Jul 16, 2007 - 2:34 PM
applejax
Joined Mar 16, '07
From the gap that lies between one microsecond and the next...
-ignore me-
This post has been edited by applejax: Jul 16, 2007 - 2:34 PM
The poster is not bound by any accuracy, stated or implied, of the previous post. Any similarities to actual people, fictional or real, may or may not be a coincidence.
--applejax
post Jul 22, 2007 - 7:09 PM
lockman999
Joined Jul 22, '07
From Houston, TX
This procedure is for ST204 97-2000 according to a remote programming manual. I hope it helps.
1. Have all remotes you want to program with you.
2. Ensure security system is disarmed and all doors are closed.
3. Open hood.
4. Open drivers door, get in, close door.
5. Within ten seconds insert key in ignition, turn to on position and back to off position 5 times. Do not remove key. (Red security led will illuminate and alarm will sound.)
6. Open and close driver door one time.
7. Turn ignition on and back off one time. Do not remove key.
8. Press either button on the first remote. (Security led will turn off for one second to indicate successful program.)
9. Repeat steps 6-8 for up to 4 remotes.
10. When all remotes have been programmed open driver door and get out. Do not close door yet.
11. Close hood.
12. Close driver door. (Security led will turn off and alarm will sound one time.)
13. Check remote for proper operation.
This post has been edited by lockman999: Jul 22, 2007 - 7:12 PM
Lo-Fi Version Time is now: December 4th, 2024 - 4:12 AM
