> ST205 IC water pump location, Looking for a diagram
post Jul 11, 2007 - 12:18 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
I'm looking for the stock position of the st205 IC water pump. I got my hands on a 205 pump bracket (thanks Jeremy).
I know its on the drivers side frame rail. Just wondering if any swapper has bolted this bracket on before.
Should this bolt right up ? Or would I need to drill two holes ?
Thanks,
DEF
I will return one day.
post Jul 11, 2007 - 12:35 PM
Kadett
Joined Mar 17, '05
From The Netherlands
Just looked at my car, Its underneath the stock location of the filterbox. But I can't see where it precisely bolts on to without removing the box.
This post has been edited by Kadett: Jul 11, 2007 - 12:36 PM
post Jul 11, 2007 - 12:47 PM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE(Kadett @ Jul 11, 2007 - 6:35 PM) [snapback]577369[/snapback]
I've got that bit of my st202 exposed at the moment so I can take any pictures you want.
This post has been edited by BloodyStupidDavey: Jul 11, 2007 - 12:48 PM
post Jul 11, 2007 - 1:18 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(Defgeph @ Jul 11, 2007 - 10:18 AM) [snapback]577364[/snapback]
Thanks,
DEF
Yup, directly on/under the frame rail. The inlet/outlet face the back of the car. I can't tell you if it bolts up to your car though...
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Jul 11, 2007 - 3:06 PM
nsxtypeR
Joined Jan 3, '06
3 holes are already pre-drilled.
Located underneath the battery/stock air filter
I know because I just placed a ST205 ic-pump onto my own swapped ST202.
This post has been edited by nsxtypeR: Jul 11, 2007 - 3:09 PM
JDM ST205
post Jul 11, 2007 - 3:52 PM
I used the bracket, but was unsure exactly how to bolt it in. I believe I made up my own location near the frame rail.
This post has been edited by Supersprynt: Jul 11, 2007 - 3:54 PM
post Jul 11, 2007 - 8:20 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(nsxtypeR @ Jul 11, 2007 - 3:06 PM) [snapback]577419[/snapback]
Good trade.
post Jul 11, 2007 - 10:49 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Lo-Fi Version Time is now: December 2nd, 2024 - 8:53 AM
