3SGTE TO 96 ST ENGINE MOUNTS |
Jul 11, 2007 - 1:42 PM |
Enthusiast Joined Jun 21, '07 From Peachtree City, GA USA Currently Offline Reputation: 0 (0%) |
I have the front left and front right engine mounts from a ST205. Can I use my rear stock mounts or do I have buy the rear st205's as well?
Jul 11, 2007 - 2:05 PM |
What do u mean front left and right? Theres front & rear, passenger side and drivers side.
It depends on your tranny. Are u using E153? ST205 mounts front and back. S54? GT mounts front and back. -------------------- |
Jul 11, 2007 - 2:06 PM |
Enthusiast Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
QUOTE(jshawn96 @ Jul 11, 2007 - 11:42 AM) [snapback]577394[/snapback] I have the front left and front right engine mounts from a ST205. Can I use my rear stock mounts or do I have buy the rear st205's as well? if you are using a stock GT transmission, you should be able to use Stock GT Engine mounts and brackets for the front and back. ST mounts will not work. If you are going with a e153 tranny from the mr2 turbo then you WILL need the rear mount and bracket from the ST205 and you could then use a regular GT mount and bracket for the front mount where the radiator is. Hope this helps |
Jul 11, 2007 - 2:12 PM |
Sorry, I meant passeger side and drivers side. Thanks for the info though. I just bought a C-One trd set so that should cover me.
Lo-Fi Version | Time is now: December 2nd, 2024 - 3:02 AM |
