> What amp for these subs?, audiobahn 10" subs
post Jul 11, 2007 - 7:16 PM
CelicaST_CALI
Joined Feb 28, '07
OK well i have made the decsion that im getting 2 Audiobahn DUB1000 10" 1000W Dual 4-Ohm Subwoofers.
heres the specs:
Sensitivity: 91.1 dB
RMS Power Range : 600 Watts
Peak Power Handling: 1000 Watts
Impedance: Dual 4 Ohm
Low Frequency response: 23 Hz
High Frequency Response: 500 Hz
Diameter: 10 Inch
Features
PHAT 2" Foam Surround
Non-Pressed, Non-Transfer Paper Cone
KM3 Coated for Virtually No Cone Distortion
Dual 4 Ohm
2 or 8 Ohm Operation
Multi-connect Lug Lock Terminals
Includes Chrome-Plated Cast Aluminum Grille
Magent Weight: 120 oz
Voice Coil: 2.5" Dual 4 Ohm
Operation: 2 or 8 Ohm
Mounting Depth: 5"
Hide Cutout: 9 1/4"
Outer Diameter: 10 7/8"
And a pics:
i have a pic of how i want to mount them i photoshoped but photobucket wont let me upload it...
MY QUESTION:what amp should i get for these?I plan on getting 2 6.5"/8" dub speakers for the doors down the line,the cureent audio system is all stock..
BANNED. for life, you moron.
post Jul 11, 2007 - 9:15 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
http://www.edesignaudio.com/edv2/product_i...;products_id=44
this is the one you want with the coils in parallel as well as the subs...
1ohm = 1200 watts/2 is 600 watts a sub
you're going to have to redo your entire electrical system for those subs
new battery, alternator if you can find one, 0/1 gauge wire, grounded back to the battery not the trunk... capacitor, the whole deal
any other good name amp company too with the same specs will work but you want 1200w at 1 ohm, do not exceed that! JL, Crossfire, JBL are all great amps to look for... i recommend ED but i've used others as well for installs
This post has been edited by pittfirefighter: Jul 11, 2007 - 9:17 PM
Breaking Axles...
post Jul 11, 2007 - 10:36 PM
CelicaST_CALI
Joined Feb 28, '07
why can i not exceed one ohm?and what about this amp,how many channels should it be if im jsut powering the subs?Also can i run my aftyermarket speakers off teh stock amp?Where is teh stock amp located?
This post has been edited by CelicaST_CALI: Jul 11, 2007 - 10:42 PM
post Jul 12, 2007 - 1:57 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
QUOTE(CelicaST_CALI @ Jul 11, 2007 - 10:36 PM) [snapback]577621[/snapback]
cannot exceed 1200watts at one ohm is what i'm saying... more than 1200 watts and you'll run risk of blowing the subs.... that amp is a one channel amp... to get that kinda power you will want to use a one channel amp or you'll pay dearly for a two channel amp to power those subs right... so you'll only be able to power the subs off of it, ST's do not have a separate amp like GT's do, its built into the head unit with the four 6.5 speakers.... and puts out roughly 15watts per speaker or 4 channels
Breaking Axles...
Lo-Fi Version Time is now: December 2nd, 2024 - 7:01 AM
