> lowering springs making noise
post Jul 13, 2007 - 12:27 PM
KaJuN
Joined Apr 12, '07
From Winkler
anyone else have this problem with lowering springs? sometimes when my car is parked stationary, and i turn the wheel, the spring (i presume) makes a creaking noise. i have kyb shocks, and tein springs, so it's not that i have bad quality stuff or anything. i haven't yet taken it apart to take a look at it, but i probably will sometime in the near future. if anyone has any thoughts on this, that'd be pretty sweet. Thanks.
post Jul 13, 2007 - 1:11 PM
some times the noise is caused by the spring binding on the upper perch.
when you turn the wheel, the spring (if not lubed up top or on a bearing system) will bind and twist, thats the creak you hear, some times you'll hear a pop as well.
Bearing grease on the very top coil will help
(this could be 1 of a few reasons)
post Jul 14, 2007 - 2:41 AM
soven
Joined Mar 14, '05
From Auckland,New Zealand
both sides or just one side?
Lo-Fi Version Time is now: February 19th, 2025 - 10:09 PM
