> NEED AMP HELP ASAP!!, maybe the remote wire???
post Jul 17, 2007 - 2:02 PM
stud97023
Joined Feb 18, '07
From Clackamas, Oregon USA
i justt hooked up my whole system yesterday. i turned the car on and i had nothing comming out of the speakers. the little light on the amp didnt even light up. I think its either because i grounded it wrong, or because of my remote wire. I attached it to the powerantenna cable comming off the headunit. is this the right wire to splice it to? or did i do it all wrong???
post Jul 17, 2007 - 2:19 PM
CelicaST_CALI
Joined Feb 28, '07
how did u ground it and where?
BANNED. for life, you moron.
post Jul 17, 2007 - 2:43 PM
94celigts
Joined Jun 13, '07
From Whitby, ON, CAN
you should have an amp wire coming from the headunit that u splice into not the antenna wire?
post Jul 17, 2007 - 3:38 PM
stud97023
Joined Feb 18, '07
ok, so i grounded it to the side wall behind the trunk siding on the driver side. I just scraped off the paint and screwed the wire down. And i didnt mean the actuall antenna wire, there is a blue wire with a white stripe on it that says power antenna. Thats the one i ment. I dont know tho.....
post Jul 17, 2007 - 6:58 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
change your headunit to radio and see if the amp turns on.
Otherwise, check the power cable fuse and that the ground cable is connected properly
post Jul 17, 2007 - 7:22 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
splice into the all blue power wire for the headunit. then makesure your ground is on bare metal.
Lo-Fi Version Time is now: February 22nd, 2025 - 7:18 AM
