Enthusiast ![]() Joined Jan 14, '06 From New York Currently Offline Reputation: 0 (0%) ![]() |
For anyone using a 3SGTE motor, do you know the part number for a set of spark plugs a step COLDER than those of stock? I need colder spark plugs because I plan on running higher boost! I need the part number.
Thanks! -------------------- I drive a Celica. Anything "less" is just a car! |
QUOTE(nemesis @ Jul 17, 2007 - 8:52 PM) [snapback]579572[/snapback] For anyone using a 3SGTE motor, do you know the part number for a set of spark plugs a step COLDER than those of stock? I need colder spark plugs because I plan on running higher boost! I need the part number. Thanks! NGK = BKR7 -------------------- Former Team 5SFTE pro member ;)
Thanks a whole lot! I appreciate it!
nemesis QUOTE(presure2 @ Jul 17, 2007 - 8:44 PM) [snapback]579592[/snapback] QUOTE(nemesis @ Jul 17, 2007 - 8:52 PM) [snapback]579572[/snapback] For anyone using a 3SGTE motor, do you know the part number for a set of spark plugs a step COLDER than those of stock? I need colder spark plugs because I plan on running higher boost! I need the part number. Thanks! NGK = BKR7 -------------------- I drive a Celica. Anything "less" is just a car! |
![]() Enthusiast ![]() ![]() ![]() Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) ![]() |
They usually go by NGK 6097 at part stores
This post has been edited by Gary: Jul 18, 2007 - 10:04 PM -------------------- _Gary
I went to Strauss and Autozone chains and they don't cary BKR7E. They do, however,carry the stock, BKR6E. Any sugggestions as to where next I should try?
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) ![]() |
Autocrap is junk.
IMO I wouldn't waste my time going there for most things. Try Napa -------------------- ![]() |
I also got mine from Napa.
QUOTE(nemesis @ Jul 19, 2007 - 8:32 PM) [snapback]580357[/snapback] I went to Strauss and Autozone chains and they don't cary BKR7E. They do, however,carry the stock, BKR6E. Any sugggestions as to where next I should try? Thanks! those are the stock heat range plugs. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Lo-Fi Version | Time is now: February 20th, 2025 - 10:45 AM |
