Air fuel gauge and oil pressure gauge help on a GT., Air fuel gauge and oil pressure gauge help on a GT. |
Jul 21, 2007 - 6:42 PM |
Enthusiast Joined Mar 23, '06 From Nashville Tennessee Currently Offline Reputation: 5 (100%) |
Im trying to help a freind hook up his Air Fuel gauge and Oil Pressure gauge to his GT,But since i do not own a GT or have any experience with the 5sfe,Im asking for instructions on where the oil sending unit is,and where he would find the correct place to connect the the wire on the o2 sensor ?
Pictures would be extreamly helpfull. Along with tips on where to find power and run his lines. -------------------- |
Jul 21, 2007 - 10:25 PM |
Enthusiast Joined Feb 23, '07 From Albany, NY Currently Offline Reputation: 3 (100%) |
the air fuel guage isnt too hard, i dont own a 5s either but you should look at his exhaust manifold and there should be a sensor with a wire running off it somehere, tap the air/fuel guage into that.
As for the oil pressure guage i think your gonna have to get an adaptor (how i would do it, dont know if theres another way), u can find one on eBay, search for "glowshift" in ebay stores, then search celica oil in their store. It should look like a blue sandwhich, they have installation instructions. good luck! *edit* Didnt see that you needed tips for power wiring, i would say ground to chassi and power from the cig lighter. As for running the lines wrap them all in red or blue or watever wire loom and run them through a grommet in the top left of your engine bay, if u cut a little hole in it (be carefull) you can run the wire all the way down and out to where the passengers feet sit, then from there i would run them behind his dash and up his a-pillar( it comes off easily) If you got ?s please ask i wanna help. Pic of grommet on my car: Sorry i made it kinda fast.... This post has been edited by Redline08: Jul 21, 2007 - 10:36 PM |
Jul 21, 2007 - 11:45 PM |
well ive run all the lines on my celica and i do have a sandwich.
But i dont know anything about the 5s all i think he will need is the T that goes where the stock oil temp sending unit is. And well since im in Tenn and he is in Mass im not really there to help him,so im going to send him this thread so im looking to get all the help for him that i can. Also he will be mounting the gauges on his a pillar.So i dont thing running his wires to the left side of the car will work to well. This post has been edited by Shocker: Jul 21, 2007 - 11:54 PM -------------------- |
Jul 21, 2007 - 11:49 PM |
uh ok??!?
lol i didnt really get that but as long as it helped its all good |
Jul 21, 2007 - 11:52 PM |
QUOTE(Redline08 @ Jul 21, 2007 - 11:49 PM) [snapback]580994[/snapback] uh ok??!? lol i didnt really get that but as long as it helped its all good oh yeah im tired,I was just stating that i have run the wires and installed gauges in my car,But this 5s is new to me and since i cant see it in person im trying to get all the information i can for him. -------------------- |
Jul 21, 2007 - 11:54 PM |
oo yea its like 1 here and im a lil out of it, but i get u now, i hope he gets it, i know he'll get the air/fuel gauge, thats simple stuff
Jul 25, 2007 - 5:15 AM |
Enthusiast Joined Mar 6, '06 From massachusetts Currently Offline Reputation: 30 (97%) |
Complete noob question for you guys. Where in hell do I connect the air fuel ration gauge? I am sorry but I have no idea where these hook up. Thanks for the illustration too man. I already have a hole in my firewall where my system's power wire is run through it.
Jul 25, 2007 - 2:59 PM |
air/fuel? look on your exhaust manifold, there should be a sensor bolted on to it that has a wire runnin off it, that wire is where u connect the air/fuel gauge.
Jul 25, 2007 - 3:06 PM |
Now should I splice or no splice? I've heard its a bad idea to splice but I want to make sure.
Jul 25, 2007 - 3:13 PM |
ey, i wouldnt. I would take a carpet knife and cut the wire down to the metal all the way around, make two about an inch apart, then cut the rubber with the carpet knife between the two "cuts". Peel off the rubber and you should have a totally intact wire with the insulation missing for about an inch. Then wrap the air/fuel gauge wire around that and solder, then cover the whole thing up with some heat wrap or electrical tape.
Its hard to explain but dont cut the wire in case you screw up stripping it alot and end up without enough wire to reach the original sensor. |
Jul 25, 2007 - 5:13 PM |
Is there any way someone could get me a pic of this wire? I think I have the right one but I'm not 100% sure.
Jul 25, 2007 - 8:22 PM |
trust me, if it comes off a sensor that bolts into your exhaust manifold its the right wire.
Jul 25, 2007 - 8:24 PM |
lol thanks bud. Ill try and install it tomorrow morning. Its a little sensor thats right next to my intake so I'm sure thats the one. Thanks for all your help dude
Jul 26, 2007 - 9:13 AM |
wait not your intake. your exhaust!! lolll
get a pick up before u cut the wire, i dont have a gt but i still know the right wire... |
Jul 26, 2007 - 7:08 PM |
lol then I have no idea what wire it is. After I thought about it I knew the one next to the intake wasn't the right wire.
Jul 26, 2007 - 8:11 PM |
Enthusiast Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
ive always tapped into a wire by the ecu then just ran it to the gauge.. not certain as to which wire you would wanna tap on a 5s though..
-------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Sep 24, 2007 - 2:24 AM |
Enthusiast Joined Aug 3, '07 From Bellevue, Nebraska Currently Offline Reputation: 28 (100%) |
QUOTE(jason @ Jul 27, 2007 - 10:11 AM) [snapback]582774[/snapback] ive always tapped into a wire by the ecu then just ran it to the gauge.. not certain as to which wire you would wanna tap on a 5s though.. Which wire is it on the ecu? pic? -------------------- ~Andy
Check out my Droid Goodies | My Flickr |
Sep 24, 2007 - 5:01 PM |
Enthusiast Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) |
QUOTE(Redline08 @ Jul 25, 2007 - 2:59 PM) [snapback]582289[/snapback] air/fuel? look on your exhaust manifold, there should be a sensor bolted on to it that has a wire runnin off it, that wire is where u connect the air/fuel gauge. tap into the harness wire though..not the actuall o2 wire its self. If you tap into the o2 wire its self, you will get a bad signal because the wire is what gives the sensor its reading. It takes a sample of the air outside and air inside and compair the air/fuel mixture and if you tap into the wire its self, the sensor will take a bigger sample of air from the outside and throw off your reading/acutall a/f reading to the comp. |
Lo-Fi Version | Time is now: December 4th, 2024 - 6:48 AM |
