> st202 climte control in st204.., is that possible?
post Jul 22, 2007 - 11:15 AM
lubu
Joined Apr 2, '07
From Great Western Plateau
juat wondering what would i need in order to swap the auto climate control from an st202
to an st204...tired of its getting really hot and really cold and adjusting all the time.
found this..
is that all the stuff i need for the swap??
edit: has basically every thing excep the compressor..and the a/c unit
This post has been edited by lubu: Jul 22, 2007 - 11:16 AM
98% completion
aaRon
post Jul 22, 2007 - 2:19 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
Cant you just switch it to self adjusting?
I really like the auto adjusting feature on my celica.
On second read, do you currently have the control unit that has the temperature dial or the one with the red to blue one?
This post has been edited by soven: Jul 22, 2007 - 2:21 PM
post Jul 22, 2007 - 2:21 PM
lubu
Joined Apr 2, '07
lol i dont have that feature..mine is a manual a/c, thats why im swapping to auto climate like yours...
98% completion
aaRon
post Jul 22, 2007 - 2:25 PM
soven
Joined Mar 14, '05
ah sorry, thought you meant the other way round.
Good luck. I had a brief look behind the aircon units of both of the types and they looked pretty different. Will probably open them up again this weekend and see whats the difference if you have not found your answer by then.
post Jul 22, 2007 - 4:04 PM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE (soven @ Jul 22, 2007 - 8:25 PM) *
They are very different. To do the swap you'll need:
* an extra engine bay sensor
* JDM climate control compressor (pump) in the engine bay. It is different to the US/UK one.
* replace the temperature sensor inside the aircon heat exchanger (the middle box behind the glove box)
* a different aircon resistor pack
* an aircon power transistor (not fitted for aircon)
* a light sensor (goes into the top of the dashboard)
* a cabin temperature sensor (goes under the steering wheel)
* an air tube that goes between the cabin air sensor and near the drivers' foot rest
* two short aircon wiring looms
* cabin wiring loom from a donor car with climate control
* different aircon amplifier module
* an extra relay (climate control high speed relay)
* an air vent mode solenoid from donor car (they are different)
* a temperature mix solenoid from donor car (solenoid not fitted in aircon)
* temperature mix actuator cable from donor car (they are different)
* climate control (the unit with switches on that goes in the center console
* climate control ECU (not fitted in aircon, sits on top of the main ECU)
You'll need to completely unplug the cabin wiring loom then remove the arm rest, lower centre console, steering wheel, dashboard. You'll then need to combine your old loom with the donor loom; change over the aircon heat exchanger temperature sensor; run wires to the engine bay sensor; diagnostics connector and compressor; and install the remaining two cabin sensors. Install all the remaining bits, attach the cabin wiring loom to the dashboard again and put everything back together.
In short, the work involved is probably a little short of an engine swap. It isn't really worth the effort involved unless you like a challenge or really really want climate control.
This post has been edited by BloodyStupidDavey: Jun 2, 2008 - 4:28 PM
post Jul 22, 2007 - 7:07 PM
soven
Joined Mar 14, '05
ouch.
but I must say that the auto adjusting climate control is alot better than the manual one. I drive my ss3 more and this is one of the reason laugh.gif
post Jul 23, 2007 - 1:37 AM
lubu
Joined Apr 2, '07
QUOTE(BloodyStupidDavey @ Jul 23, 2007 - 5:04 AM) [snapback]581213[/snapback]
QUOTE(soven @ Jul 22, 2007 - 8:25 PM) [snapback]581177[/snapback]
You'll need to completely unplug the cabin wiring loom then remove the arm rest, lower centre console, steering wheel, dashboard. You'll then need to combine your old loom with the donor loom, change over the aircon heat exchanger temperature sensor, run wires to the engine bay sensor and install the remaining two cabin sensors. Install all the remaining bits, attach the cabin wiring loom to the dashboard again and put everything back together.
thanks alot...i'll give it a try. will update as i go.
98% completion
aaRon
post Jul 24, 2007 - 6:40 AM
lubu
Joined Apr 2, '07
with regards to those 3 sensors above...do you know where can i find them...and do you have any pictures?
98% completion
aaRon
post Jul 30, 2007 - 6:03 PM
wojtas
Joined Jun 11, '06
From Europe-Poland
I also have problems with connecting climate control. Firstly i wanted to put it in my celica st then to gt and now i've gt4 biggrin.gif And I still have no climate control.
So maybe we can help each other.
post Aug 2, 2007 - 5:52 PM
BloodyStupidDave...
Joined Nov 14, '06
QUOTE(lubu @ Jul 24, 2007 - 12:40 PM) [snapback]581820[/snapback]
I've given the location in the car for each of them above. You'll need to find a JDM car.
engine bay sensor:
sorry, I don't have a picture of this
light sensor:
^^ middle one in the above image
cabin temperature sensor:
post Aug 2, 2007 - 6:46 PM
wojtas
Joined Jun 11, '06
From Europe-Poland
thx for photos
Where exacly is this sensor in engine bay? My friend has JDM celica so I will look but I don't know how it looks....
And what about wiring? connectors are different.... and I'm not sure how to work it out...
post Aug 2, 2007 - 11:59 PM
lubu
Joined Apr 2, '07
QUOTE(BloodyStupidDavey @ Aug 3, 2007 - 6:52 AM) [snapback]584781[/snapback]
engine bay sensor:
light sensor:
thanks bud...now i gotta wait and see whats he going to give me...did say all the looms and sensors are included.
wojtas, let me try my luck biggrin.gif . honestly i dont think he'll give me all the stuffs i need but i'll update you on this.
cheers
98% completion
aaRon
post Aug 3, 2007 - 2:41 AM
BloodyStupidDave...
Joined Nov 14, '06
QUOTE(wojtas @ Aug 3, 2007 - 12:46 AM) [snapback]584789[/snapback]
I don't know. That is the last piece of the puzzle for me. I need to trace the blue/white, yellow and yellow/black wires that go from the cabin into the engine bay. It may be an additional 1-wire or 2-wire sensor or a different existing sensor.
As I said above, you'll need to find a donor car, get to the wiring looms and unpick them to seperate the individual wires and connectors you need. It is a big job.
Plus these two looms:
This post has been edited by BloodyStupidDavey: Aug 3, 2007 - 5:13 PM
post Aug 3, 2007 - 3:48 PM
stud97023
Joined Feb 18, '07
From Clackamas, Oregon USA
if you can pull this off man, you are a god haha
post Aug 3, 2007 - 5:00 PM
wojtas
Joined Jun 11, '06
From Europe-Poland
ok. I have everything that goes under dashboard and thats my problem... because everything is from celica JDM (rhd) and my gt4 is LHD.... everything is different ... even the colours of the main cables kindasad.gif I will try to get the JDM wiring diagram
post Sep 4, 2007 - 6:12 PM
lubu
Joined Apr 2, '07
anyone can help I out??
I need a EWD of the auto climate control...and I cant find it. I'll do a write-up if I can pull this off.
98% completion
aaRon
post Sep 12, 2007 - 7:46 PM
wojtas
Joined Jun 11, '06
From Europe-Poland
same problem frown.gif Nobody from japan replied to my question about the wiring diagram of it... frown.gif I'm stuck
post Jun 2, 2008 - 4:46 PM
BloodyStupidDave...
Joined Nov 14, '06
QUOTE (BloodyStupidDavey @ Aug 3, 2007 - 8:41 AM) *
QUOTE (wojtas @ Aug 3, 2007 - 12:46 AM) *
Okay, there are seven additional wires that need to be added to the 3s-ge engine wiring loom::
Five additional wires for the 3s-ge engine wiring loom in the engine bay:
A yellow wire and a blue wire that run around the passenger wheel arch.
A yellow/black wire that runs to the compressor plug.
A yellow/green wire from the ECU to the diagnostic port.
A blue/white wire that goes to the throttle sensor.
yellow/black runs from pin 3 of the 8-pin white or black connector at the bottom middle of the passenger footwell to pin 3 of the compressor plug in the engine bay.
The yellow and yellow/black wires need to be added to the engine bay wiring loom that runs from the passenger footwell arround the front passenger wheel arch and on to the fuse box and crash bar. The two wires run to the ambient outside air temperature sensor at the bottom of the radiator middle bracket bar. yellow/black runs from pin 1 of the 26-pin ecu connector.
Finally, there is a yellow/green wire that runs from the diagnostic port (CCo pin) to the engine ECU. On the 3s-fe it is pin 7 of the 26-pin ECU connector (also CCo pin), on the 3s-ge it is pin 8 of the 12-pin connector. The wire is spliced, the third leg runs to pin 15 of the 19-pin white connector behind the radio. The other side runs to a two pin connector under the driver's seat. The return wire is brown running from the driver's seat through pin 16 of the 19-pin white connector and to the earthing point near the ECU.
There are a couple of wires that run along the engine bay loom inside the body of the car (they don't cross the firewall):
blue/yellow to the engine ECU.
blue/white to the idle up / aircon sensors assembly.
blue/yellow runs from the 8-pin white or black connector at the bottom middle of the passenger footwell. It is pin 7 on that connector and runs to the engine ECU. On the 3s-fe engine (94-96) it is pin 15 of the 22-pin connector.
There is another blue/white wire - just a different colour for an existing wire. On the 3s-fe the same wire is red/blue, on the UK 3s-ge it is purple/white. It goes to the idle up / aircon sensors assembly in the engine bay (back of the bay passenger side, just below the window and next to where the loom crosses the firewall into the cabin.
The easiest way to do the wiring is to both keep the st202 relay and fuse and also use the st204 relay. If you are going to go this route, you need to splice the blue/white wire from pin 8 of the white 8-pin plug (10877) into the purple wire at pin 8 of the smaller orange plug (11556) on the climate control. Don't cut the purple wire, just splice the blue/white wire into it. This is the signal to turn on the blower via the blower relay. It is connected to ground when the blower should be running.
This post has been edited by BloodyStupidDavey: Jan 10, 2009 - 11:13 AM
post Jun 2, 2008 - 7:18 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
hows this going?
post Jun 2, 2008 - 8:03 PM
lubu
Joined Apr 2, '07
QUOTE (stephen_lee @ Jun 3, 2008 - 8:18 AM) *
hows this going?
No progress, I cant get ahold of the EWD for the auto-climate... kindasad.gif
edit: just saw BloodyStupidDavey's post..Ill look into it when I have time.
This post has been edited by lubu: Jun 2, 2008 - 8:06 PM
98% completion
aaRon
Lo-Fi Version Time is now: February 17th, 2025 - 8:22 AM
