Another cruise control problem, The light comes on, but cruise never actually works |
Jul 23, 2007 - 1:00 PM |
Enthusiast Joined Aug 15, '06 From MICHIGAN Currently Offline Reputation: 1 (100%) |
I took my car to a shop awhile ago, and along with the speedometer not working, they fixed the cruise. My cruise control worked for a long time, but now it doesnt. I read a bunch of posts where other people had problems with it, and I checked for the most common symptom which was the back of the button popping out... Mine looks good I think. Anyways, the cruise light comes on and turns off when it is supposed to, but never actually works with the engine. I noticed that there was a cruise control actuator for sale in the F/S threads... Could that be the problem? Should I check it on my car, and if so, where is it located. Any suggestions would be great. Thanks for your help.
Jul 23, 2007 - 1:10 PM |
Enthusiast Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
mine does that too. i turn it on, but if i puch it really hard to set it i may have to do it twice but it will work. i think mine just needs to be cleaned.
Jul 23, 2007 - 2:21 PM |
QUOTE(mneal2_92788 @ Jul 23, 2007 - 1:10 PM) [snapback]581533[/snapback] mine does that too. i turn it on, but if i puch it really hard to set it i may have to do it twice but it will work. i think mine just needs to be cleaned. I might spray some of that contact cleaner in the switch, and then see if it works. But the problem almost seems mechanical. Not sure, but I'll give it a shot. Is it hard to take the switch apart? |
Jul 23, 2007 - 2:51 PM |
Let me know if you'd like a shipping quote
Jul 23, 2007 - 2:53 PM |
QUOTE(Supersprynt @ Jul 23, 2007 - 2:51 PM) [snapback]581611[/snapback] Let me know if you'd like a shipping quote haha Well, lets hope it doesnt come to that, but if it does, I will be getting a quote. haha Btw, where is the actuator on the car? This post has been edited by aslearvert: Jul 23, 2007 - 2:54 PM |
Jul 23, 2007 - 3:13 PM |
Its attached to the battery tray, right next to the battery.
Looks like: This post has been edited by Supersprynt: Jul 23, 2007 - 3:15 PM -------------------- |
Jul 23, 2007 - 3:15 PM |
ok thanks, I'll look at it and see if... somethings broken...? lol
Apr 11, 2008 - 7:20 AM |
Enthusiast Joined Jul 24, '07 From Canary Islands (Spain) Currently Offline Reputation: 3 (100%) |
someone can put pic(s) with the actuator installed ??
thanks. -------------------- |
Apr 11, 2008 - 11:52 AM |
check fuses my friend. check plugs.
make sure everything is conected, and getting energy. Otherwise you would be spending extra tax dollars (from your rebate ) cheers. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Apr 11, 2008 - 12:24 PM |
Enthusiast Joined Aug 11, '07 From Corona, CA Currently Offline Reputation: 4 (100%) |
^^^x2 with what he said. maybe somehow it just got a lil disconnected..mine was totally disconnected before i decided to take it out lol
-------------------- Pandelica 2.0 in progress. |
May 7, 2008 - 8:32 AM |
I've checked the fuse box in the car and the one under the hood, but I cant tell which is the cruise control fuse. None of them are labeled cruise, cruise control, or cc... or anything. Does anybody know where its at?
thanks for your help |
May 7, 2008 - 10:19 PM |
Enthusiast Joined Dec 16, '07 From chicago Currently Offline Reputation: 0 (0%) |
i had this same problem and it turned out to be real simple. look behind the cruise control lever and see if this dinky little plastic cover came off. it doesnt seem well engineered and tends to pop off or get loose (especially if there are frequent changes in temperature. winter in my case). when this happens the contacts dont always touch. the fix simply involves popping it back in.
my two cents. hope it helps -------------------- i love how my wheel hopping, corner rolling, one wheel wonder celica looks XD |
Lo-Fi Version | Time is now: November 27th, 2024 - 8:26 AM |
