which 3sgte did you swappers use?, which one? |
Aug 2, 2003 - 9:52 PM |
Enthusiast Joined Jun 26, '03 From Wisconsin Currently Offline Reputation: 0 (0%) |
What kind of 3S-GTE did you use? I am thinking about getting one from a ST185 but I remember the problems my cousins All-Trac went through(USDM related??). However it was one mad quick car and I'm close to positive it was abused by previous owners.
-------------------- i am awesome
Aug 3, 2003 - 4:47 AM |
Enthusiast Joined Sep 13, '02 From BC, Canada Currently Offline Reputation: 0 (0%) |
what sort of problems are you talking about?
and to answer your big question, it all depends on what you want... i assume that if you're going with a swap that you're getting a JDM 3s-gte, basically everyone who's done the swap has done it with the ST185 and this is for a bunch of reasons; cost (cheaper than the ST205), and availability of parts (it's said that the ST185 has more parts readily available but that's questionable because those with the ST205 say that they can use alot of ST185 parts) Teyaku has done the swap with a ST205 which makes his cool and more original... but most people go with the ST185 because it's a little more practical (no diss the Teyaku who has an awesome vison for his ride IMO) |
Aug 3, 2003 - 10:59 AM |
Went with the ST185 (JDM). W/E parts you need you can just go and order them and get them the next day.
Oh and GET A CLIP - trust me on this, months later still sourcing some parts and figuring stuff out. Even if it takes you another 6 months to get more money, you wont regret it - buy the clip!!!! -------------------- |
Aug 3, 2003 - 11:06 AM |
Enthusiast Joined Aug 30, '02 From Ohio Currently Offline Reputation: 0 (0%) |
what about an Mr2 turbo engine??
would that be easier and cheaper then the ST185?? Less HP maybe?? -------------------- Jared Harwell
Aug 3, 2003 - 5:00 PM |
That's also kinda what I was asking, would it matter if it was an MR2? They are just as easy to find, but I'm not sure how different everything is because of where the motor is. -------------------- i am awesome
Aug 3, 2003 - 6:39 PM |
Enthusiast Joined Aug 2, '03 From Anchorage, AK Currently Offline Reputation: 0 (0%) |
how much does a clip from an st185 usually cost?
Aug 3, 2003 - 6:42 PM |
there is a search button here
check the sticky up top of this forum for the feasible engine swaps then scroll down to the bottom.. there are a few places that sell clips |
Aug 3, 2003 - 7:52 PM |
Enthusiast Joined Nov 15, '02 From Corona & Vallejo, CA Currently Offline Reputation: 0 (0%) |
MR2's use the same motor... you'll just need to source more parts. I wouldn't recommend going with a MR2 clip. Talk to Dirty on Celica.net. He'll tell you how much of a beyatch it was sourcing parts. There's about 13 different parts that will need to be sourced.
Aug 4, 2003 - 12:04 PM |
Enthusiast Joined Apr 15, '03 From San Jose, CA, USA Currently Offline Reputation: 1 (100%) |
I'd say go all the way if your going for it at all. I'd say 205. Everyone is talking about all these parts you would need! What would be so different from a 185 gte engine? And how much stuff are yall replacing so often on your current engines? what makes you think you would need parts so often for your swapped engine? just get a few extra belts no and have em on stock, and I dont know what else you would need!?
edit: all the pumps and altenator and stuff shouldn't be to different from other toyota engines. This post has been edited by Chrobis: Aug 4, 2003 - 12:04 PM |
Aug 4, 2003 - 1:13 PM |
- The timing belt b/w a 3rd gen and 2nd gen is a tooth off. - The water pump does NOT match. You MUST use a 3rd gen water pump with a 3rd gen motor, otherwise using a 2nd gen water pump will cause over heating. - Wiring harness is more complicated with the 205 than the 185. Everything else (for the most part) is interchangeable. Good luck trying to get the aforementioned parts. I'm still waiting for my water pump... grrr... |
Aug 4, 2003 - 4:48 PM |
Enthusiast Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
is the engine worth the down time to you? Like now looking back..i dont think i could go without a car for that long...maybe you have another one not sure just wondering |
Aug 4, 2003 - 5:07 PM |
In a word, yes! I've got big plans... |
Aug 5, 2003 - 12:04 PM |
Enthusiast Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) |
The 3rd gen also has the following changes over the 2nd gen:
lower compression (8.5 vs 8.8) better turbo better intercooler use's MAP instead of AFM better injectors (540 vs 440) better trans (not beneficial for FWD cars, but its easy to sell off ) bigger throttle body (3" vs 2") far better head (a stock 3rd gen had flows as much as a fully ported 2nd gen head) better intake manifold stock oil catch can stock oil filter relocator better cooling oil pan better stock ECU All of the parts listed above are not interchangeable and are not sold in the US. There are also a lot of minor difference between the two engines that can cause problems - wiring harness, sensors, brackets, gaskets, plug wires... you cant even get a valve cover gasket in the US for the 3rd gen without special ordering it from Japan. The real question is what type of performance you want. If 300HP is a good limit, go with the ST185. If you want more - go with the 205. If you want a LOT more, then it doesn't really matter, because you'll be modifying everything anyways. In comparing USDM and JDM ST185 engines - the JDM does not have a EGR and the JDM ECU has more aggressive fuel maps. Big deal! You can have a EGR block-off made for the US engine for $20, and I've seen the JDM ECU's for around $100. The only time it matters that the engine is JDM is in the rare occasion that the engine is the ST185RC version, which has the better turbo and better intercooler. This post has been edited by scothaniel: Aug 5, 2003 - 12:05 PM -------------------- Scott
West Michigan |
Aug 5, 2003 - 12:09 PM |
Enthusiast Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
if you bought a usdm st185 would you still ave to extend the wiring harness?
-------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Aug 5, 2003 - 12:12 PM |
Here's a pretty complete list of the differences:
http://celica.net/cgi-bin/ultimatebb.cgi?u...c;f=37;t=000315 |
Aug 5, 2003 - 12:19 PM |
When it comes to fitting any 3SGTE into the 6th gen, there will always be harness modifications. The main difference is the Fuse box - I've found it easier to use the stock harness that came with the car and modify it for the engine. You'd be surprised on how similar all Toyota harnesses are. Most of the lines are the same and just need to move relocated at the ECU harness.
West Michigan |
Aug 5, 2003 - 12:21 PM |
You won't be able to use a 185 USDM harness with a 185 JDM ECU right out the box. I know that some (maybe even a few) wires need to be rewired. |
Aug 5, 2003 - 1:43 PM |
Enthusiast Joined Apr 29, '03 From Davenport, IA Currently Offline Reputation: 0 (0%) |
Isn't it easy enough to just up the st185 JDM to the same HP as the st205 with just about the same amount of money or even less?
Aug 5, 2003 - 2:06 PM |
The difference between the 205 and 185 HP is only around 45HP, so yes, its really easy to get the 185 to the same HP as the stock 205 for much less then the cost of a 205 motor.
From there though, the 205 is much easier to push to higher HP levels. This post has been edited by scothaniel: Aug 5, 2003 - 2:10 PM -------------------- Scott
West Michigan |
Lo-Fi Version | Time is now: November 24th, 2024 - 12:28 PM |
