![]() Enthusiast ![]() ![]() ![]() Joined Jan 10, '06 From Mozambique, Africa Currently Offline Reputation: 8 (100%) ![]() |
I've decided that the only way to install my new brake discs that are 5x100 onto my 5x114 hub is to swap out the hub to 5x100. If i buy new hubs, do I need to change anything else out in order for the new hub to fit? I want to make sure that i get everything at once. Thanks!
-------------------- ![]() "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) ![]() |
On the Celica? I thought all Celicas were 5x100.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
they should be 5x100
QUOTE(BLINKYxMUNKEY @ Jul 25, 2007 - 4:44 PM) [snapback]582178[/snapback] On the Celica? I thought all Celicas were 5x100. QUOTE(LewFX @ Jul 25, 2007 - 4:56 PM) [snapback]582183[/snapback] they should be 5x100 Unfortunately, the JDM versions are not. Well at least mine isn't. -------------------- ![]() "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) ![]() |
Are you sure?
I would double check that you don't have it backwards [your kit being 5 x 114]. The ST205 is 5 x 100, including the JDM version. All the JDM 4th and 5th gen stuff is the same. I'm 99% sure ALL 6th gens worldwide are 5 x 100. If you do have 5 x 114 on your car someone has already switched them most likely. 5 x 114 is a more common size, so easier to find wheels in. If it is all you need to do is get 4 5 x 100 hubs from a Celica, and 4 wheel bearings. Press out the wheel bearings, and press the new ones in, then press in the hubs. -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) ![]() |
Just to confirm that all 6th gen celica including jdm versions ss1,2,3 , gt4 etc is 5x100
Ok. i'm going to give it another try and see if i can't get the discs on there. perhaps they have been changed by the previous owner. if they still don't fit, i'll have to purchase/find the correct hubs and wheel bearings. I'll let you all know.
So i finally got my car back from the body shop and since i had time this weekend, i tried to fit the brake discs. And of course, they didn't fit. See pics.
Here are the brake discs that i ordered. ![]() Here's how they weren't fitting. JUST off by a little bit! ![]() I measured from the left edge of one hole to the right edge of an opposite hole on both discs. Current: ![]() New: ![]() Basically, the ones on my car are closer to 5x100, than they are to 5x114. Oh well. Hubs it is then. -------------------- ![]() "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
Lo-Fi Version | Time is now: February 22nd, 2025 - 2:08 PM |
