> removing rotors/calipers & bleeding brakes?, how to..?
post Jul 27, 2007 - 3:47 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
just as the title says. does anyone have instructions on how to remove calipers and rotors and then bleed the brake lines to replace the old brake fluid with new? thanks.
post Jul 27, 2007 - 5:09 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
oh common... someone has gotta know how to do this..
post Jul 27, 2007 - 5:34 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
take wheel off
calipers are held on by 2 14mm in the rear and 17mm in the front
rotors usually just pop off, if not use a 10mm bolt inside the rotor holes on the front and turn them til the rotor pops off
bleeding brakes, rear passenger side. have someone pump the brakes 3 times and hold. use a bleeder hose on the caliper nipple and a open end 8mm wrench and turn to release fluid, tighten. release brakes. repeat twice. repeat on all sides..start farthest from reservior.
if replacing all fluid, just bleed one side til all the fluid is gone.
post Jul 27, 2007 - 7:41 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
Make sure the brake fluid reservoir does not run empty. If it does, you have to re-bleed your brakes. Keep topping it up.
post Jul 28, 2007 - 1:15 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I don't see y u have to remove rotors and calipers. U can do it without removing them.
post Jul 28, 2007 - 9:39 AM
LewFX
Joined Jan 28, '05
because hes replacing a bad caliper
post Jul 28, 2007 - 11:24 AM
cjh4l22
Joined Oct 18, '06
From cincinnati
having trouble getting rotors off. removed 4 bolts total (2x14mm and 2x17mm) and they still seem to be stuck pretty good. any suggestions anyone?
post Jul 28, 2007 - 11:49 AM
LewFX
Joined Jan 28, '05
pb blaster, breaker bar and deep impact socket
This post has been edited by LewFX: Jul 28, 2007 - 11:49 AM
Lo-Fi Version Time is now: February 23rd, 2025 - 12:52 AM
