Enthusiast ![]() ![]() ![]() Joined Jun 21, '07 From SoCal Currently Offline Reputation: 0 (0%) ![]() |
k so during in japan i went to some shops like autozone..etc
and there i some cool looking lights and i bought some kind of expensive looking super low beams which says dual range xenon blue 4600k i intended to buy it for the celica but now when i look at it it says this bulb only works for H4 12V 60/55W it looks exactly like http://www.automotivelightingusa.com/index...roducts_id=1399 can i still intall this in the 95 celica gt? P.S i also bought a shift knob for an AT but it was for gate type which i also lost my money on .... ![]() This post has been edited by mrgrape: Jul 28, 2007 - 3:52 PM |
![]() Enthusiast ![]() ![]() ![]() Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) ![]() |
QUOTE(mrgrape @ Jul 28, 2007 - 9:44 PM) [snapback]583246[/snapback] i bought some ... super low beams... but now when i look at it it says ... H4 12V 60/55W... can i still intall this in the 95 celica gt? Nope, sorry. Standard Celica bulbs are 9005 and 9006. The H4 would plug into a JDM loom or a loom modified to take the projector lights but then you would have the mechanical problem of the bulb diameter being much too big for the tiny bulb hole in the projector. If you drilled out the plastic to take the bulb, you would still have a problem with keeping the bulb securely in the lamp housing. I'm not sure the H4 bulb you have will even fit through the hole in the standard Celica housing - if it did, you would have a similar problem of how to hold the bulb in place, plus you would need to make up a 9005 to H4 converter cable and connect the third prong to a suitable wire to drive the second filament. -------------------- Davey
Items for sale |
QUOTE(BloodyStupidDavey @ Jul 28, 2007 - 10:27 PM) [snapback]583262[/snapback] QUOTE(mrgrape @ Jul 28, 2007 - 9:44 PM) [snapback]583246[/snapback] i bought some ... super low beams... but now when i look at it it says ... H4 12V 60/55W... can i still intall this in the 95 celica gt? Nope, sorry. Standard Celica bulbs are 9005 and 9006. The H4 would plug into a JDM loom or a loom modified to take the projector lights but then you would have the mechanical problem of the bulb diameter being much too big for the tiny bulb hole in the projector. If you drilled out the plastic to take the bulb, you would still have a problem with keeping the bulb securely in the lamp housing. I'm not sure the H4 bulb you have will even fit through the hole in the standard Celica housing - if it did, you would have a similar problem of how to hold the bulb in place, plus you would need to make up a 9005 to H4 converter cable and connect the third prong to a suitable wire to drive the second filament. geezus i dont even know wt u said lol i am such a noob lol i buy **** and theyre not even worth it wt do u think i should do with the light now? |
Enthusiast ![]() ![]() ![]() Joined May 3, '06 From New Hampshire Currently Offline Reputation: 2 (100%) ![]() |
ebay??
-------------------- ![]() Darin H. |
Lo-Fi Version | Time is now: February 22nd, 2025 - 2:05 AM |
