> Windscreen Washer Motor not working, My windscreen washer has ceased to function!
post Jul 29, 2007 - 4:42 AM
Racer_J
Joined May 16, '07
From Newcastle UK
Got in the car this morning to find the windscreen washers weren't working! I've checked the washer bottle for screen wash and it's full. When I press the button for the washers, I can't hear the motor running. Could this be a blown fuse somewhere or is the motor in the washer bottle shot? Anybody know?
Cheers
post Jul 29, 2007 - 3:13 PM
kerosene
Joined Jul 4, '07
From US
when i bought my car mine was fried, replaced it and everything was fine...
post Jul 29, 2007 - 4:09 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
make sure you don't have any clogs in the tubes or sprayers. if no clogs then you will probably need to get a new pump. GL
post Jul 30, 2007 - 3:29 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
I wasn't sure how much a new motor would cost so I took mine to pieces and found lots of corrosion on the internal circuit board. cleaned it off and heated up the solder again so it would connect again and its worked fine ever since.
I originally found that when I squirted the rear window the front wipers would also go, this cured that as well.
but yeah it could be a fuse, but I would think that it would use the same fuse that your wipers use so if they work then its probably something similar to mine.
post Jul 30, 2007 - 12:23 PM
Racer_J
Joined May 16, '07
From Newcastle UK
Thanks guys,
It was the motor, spent all day yesterday walking around scrap yards looking for a new one. For the record, I got one from a Corolla. Works fine.
Thanks again for the help.
This post has been edited by Racer_J: Jul 30, 2007 - 12:23 PM
Lo-Fi Version Time is now: November 28th, 2024 - 6:02 AM
